Line Graph instead of Bar graph
Hi all, I am helping my daughter with a science project where she has to measure vibration.
I followed a tutorial and I got the bar graph to show up in processing but I would like to graph it as a line graph instead. I found this page here that he modified the code from the same tutorial I used but the code as he posted does not work.
http://arduining.com/2013/08/05/arduino-and-processing-graph-example/
The people in the comments seem to have the same problems I am having with his code.
Here is my code that graphs a piezo to processing to a bar graph and it works well. I just think it would look nicer as a line graph.
Written to arduino uno
const int threshold = 25;
int sensorReading = 0;
  // initialize the serial communication:
sensorReading = analogRead(A0);
  if (sensorReading >= threshold) {
  Serial.println(sensorReading);
  else {
  Serial.println(0);
  delay(5);
and here is the processing sketch
import processing.serial.*;
Serial myPort;        // The serial port
int xPos = 1;         // horizontal position of the graph
float inByte = 0;
void setup () {
  // set the window size:
  size(900, 800);
  // List all the available serial ports
  // if using Processing 2.1 or later, use Serial.printArray()
  println(Serial.list());
  // I know that the first port in the serial list on my mac
  // is always my  Arduino, so I open Serial.list()[0].
  // Open whatever port is the one you're using.
  myPort = new Serial(this, "COM4", 9600);
  // don't generate a serialEvent() unless you get a newline character:
  myPort.bufferUntil('\n');
  // set inital background:
  background(0);
void draw () {
  // draw the line:
  stroke(127, 34, 255);
  line(xPos, height, xPos, height - inByte);
  // at the edge of the screen, go back to the beginning:
  if (xPos >= width) {
    xPos = 0;
    background(0);
    // increment the horizontal position:
    xPos++;
void serialEvent (Serial myPort) {
  // get the ASCII string:
  String inString = myPort.readStringUntil('\n');
  if (inString != null) {
    // trim off any whitespace:
    inString = trim(inString);
    // convert to an int and map to the screen height:
    inByte = float(inString);
    println(inByte);
    inByte = map(inByte, 0, 1023, 0, height);
I don't know Processing, but it sounds like your problem is a Processing problem rather than an Arduino problem. I assume there is a Processing Forum somewhere.
...R
I'm not going to wade through a boat load of vague comments to guess what YOUR problem is. Define the problem HERE, since you posted your issue HERE.
There is, but enough of us use both that Arduino-related Processing questions are OK here.
To draw a line graph you need to draw a line from the previous point to the latest point and then make the latest the previous point.
int latestHeight = height - inByte; line(xPos-1, previousHeight , xPos, latestHeight); previousHeight = latestHeight;
previousHeight must be a global int and you need to add some extra admin to get the first & last point of the graph correct.
