Hi, I'm working on a reflective sensor array at the moment which uses three RGB leds and three sensors, which I call l, m and r in my sketch for a line following vehicle.
analogRead nets the following readings (examples):
175, 33, 184 (middle of line, 33 is the black line value)
29, 134, 177 (right of the line)
179, 104, 24 (left of the line)
these are readings for the l m and r sensors respectively. I want to map these readings to
either errors, such as positive for right of line and negative for left of line. Currently I have a few else if statements, but i'm sure there is an easier way to do this. I want to use the error values for PID in another function.
here's what the relevant snippet of the sketch looks like.
void detect() {
const int bval = 50;
if (l >= bval && m >= bval && r <= bval) {
error = 2;
else if (l >= bval && m <= bval && r <= bval) {
error = 1;
else if (l <= bval && m <= bval && r <= bval) {
error = 0;
else if (l <= bval && m <= bval && r >= bval) {
error = -1;
else if (l <= bval && m >= bval && r >= bval) {
error = -2;
I don't think there is a very easy way. I can't see an easy relation between the error and the sensors. But you could make the code a bit simpler and faster by making 1 variable to check instead of 3 each time.
I also took the liberty to change all variable names. One letter variables are only good for a small scope like a for loop. Not to be a global variable. A name should tell what it is. So better a longer name that explains what it is the a short cryptic. So changed them to sensorValues and sensorThreshold. sensorValues is an array. See Gammon Tip 1.
Also added error code 100 as a out of bound error code.
int8_t detect(){
int8_t error = 0;
//check all sensors to see if they are light or dark
for(byte 1 = 0; i < 3; i++){
error <<= 1;
error |= (sensorValues[i] > sensorThreshold);
//Make that correspond with error number
if(error == 0b110)
error = 2;
else if(error == 0b100)
error = 1;
else if(error == 0b000)
error = 0;
else if(error == 0b001)
error = -1;
else if(error == 0b011)
error = -2;
error = 100; //out of bound
return error;
