line sensor (qrb1114( and led
hi
im trying to use a if else command and a line sensor to turn a led on and off.
I know the fruit works and all the pins are correct but i still can not get it to work
int const ledpin = 13;
int const senpin = 2;
  pinMode ( senpin, INPUT);
  pinMode ( ledpin, OUTPUT);
  if (senpin == 0) {
    digitalWrite(ledpin, HIGH);
    digitalWrite(ledpin, LOW);
Serial.println(digitalRead(senpin)); // print the data from the sensor
What fruit works?
But anyway:
  if (senpin == 0) {
I don't think you really meant to compare the pin number to 0 did you?
Steve
hi steve
im very new to coding, it is part of my degree. however i do not know what a fruit is or what i should put instead in the if else command
georgia
It was you who said "I know the fruit works...". I just wondered what you meant.
As for the if statement, don't you want to check the VALUE on that pin? Not the pin NUMBER? It's done correctly a few lines later in the Serial.println().
Did you actually write that code or just copy it from somewhere without understanding it? It's not a real problem if you did, many of us start out that way. But it helps if you mention it because the assistance needs to be at a different level if you're not asking about code you've put some thought into yourself.
Steve
