Hi All,
I am working on a project for school that involves have a linear actuator move in and out repeatedly.
I what the actuator to extend out to a set position and once it has reached the set point imminently start retracting to the start point and then keep repeating this until i can push a button to stop it.
I have no experience with coding so i am finding it really difficult to get it going! I have found a tutorial that shows you how to used two buttons, one that when pressed the actuator will extend to a set point and then when the other is pressed the actuator will retract. I will put the code below.
How can i adapt this code to do what i want to do?
// constants won't change. They're used here to set pin numbers:
const int button1Pin = 2; // the number of the pushbutton1 pin
const int button2Pin = 4; // the number of the pushbutton2 pin
const int relay1Pin = 7; // the number of the Realy1 pin
const int relay2Pin = 8; // the number of the Relay2 pin
const int sensorPin = 0; // select the input pin for the potentiometer
// variables will change:
int button1State = 0; // variable for reading the pushbutton status
int button2State = 0; // variable for reading the pushbutton status
int sensorValue = 0; // variable to store the value coming from the sensor
int goalPosition = 350;
int CurrentPosition = 0;
boolean Extending = false;
boolean Retracting = false;
//start serial connection
// initialize the pushbutton pin as an input:
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
// initialize the relay pin as an output:
pinMode(relay1Pin, OUTPUT);
pinMode(relay2Pin, OUTPUT);
//preset the relays to LOW
digitalWrite(relay1Pin, LOW);
digitalWrite(relay2Pin, LOW);
void loop(){
// read the value from the sensor:
CurrentPosition = analogRead(sensorPin);
// print the results to the serial monitor:
Serial.print("Current = " );
Serial.print(CurrentPosition);
Serial.print("\t Goal = ");
Serial.println(goalPosition);
// read the state of the pushbutton values:
button1State = digitalRead(button1Pin);
button2State = digitalRead(button2Pin);
if (button1State == HIGH) {
// set new goal position (where it start point is)
goalPosition = 0;
if (goalPosition > CurrentPosition) {
Retracting = false;
Extending = true;
digitalWrite(relay1Pin, HIGH);
Serial.println("Extending");
else if (goalPosition < CurrentPosition) {
Retracting = true;
Extending = false;
digitalWrite(relay2Pin, HIGH);
Serial.println("Retracting");
if (button2State == HIGH) {
goalPosition = 150;
Retracting = false;
Extending = true;
Retracting = true;
Extending = false;
if (Extending = true && CurrentPosition > goalPosition) {
//we have reached our goal, shut the relay off
Serial.println("REPEAT");
if (Retracting = true && CurrentPosition < goalPosition){
