Linear actuator + external potentiometer control
Hi there! relatively new to Arduino although I have used it previously.
I have a 6V linear actuator, with no feedback. This is the product: (https://robu.in/product/la-t8-100-stroke-length-100mm-150mm-s-6-4n-dc6v-electric-putter-electric-linear-actuator-putter-for-doors-windows/)
Works fine between max and min values. However, I now want to introduce position control. I have considered 2 options.
  1. Buy an actuator with inbuilt feedback. Pros: Easy, Cons: Expensive.
  2. Buy a rotary/linear potentiometer and use that as a replacement for the inbuilt feedback. I understand that the control, in this case, is manual, which is not an issue. Pros: Much cheaper, Cons: I don't know if that's possible (https://robu.in/product/10k-sliding-adjustable-linear-potentiometer/).
    That's where I need help. How do I use this device to control position of my linear actuator manually?
Extra: I also have a servo tester. I don't know if this works on the same principle as the potentiometer. Can it be used instead?
Welcome to the Arduino forum. What is the project you are going to use the actuator in? There is most likely some place in your project that you can add a potentiometer to give you feedback. Feedback does not have to be part of the actuator.
I have a tray that needs to slide horizontally and stop at specific distances.
If the stopping places are always in the same places, then a microswitch or IR sensor or similar may be placed at each stop. How many stops are needed?
If the movement distance is not very large, a linear potentiometer could be incorporated in your project.
