I have a project I am interested in designing and building for my home theater, and I figured it may involve servos. I am trying to toggle a switch on the back of a pair of speakers via remote control.
The speakers are physically out of reach, so I'd like to control a switch on the back of them (possibly with a linear servo?)
I would also need something to plug into the arduino to enable remote control from a Harmony remote or something similar to actually perform the action.
Here is something I found for a remote control: (would this work?)
Also, here's a servo I found. Is this what I would need? overkill? underkill?
It may be hard to see, but the top switch on the back that says "input" is what I would need to toggle, as I would have both types of connections active in my setup.
I have a background in programming and a degree in electrical engineering, so I believe I can hit the ground running once I figure out the mechanical aspects of it.
Any suggestions on approach or links to equipment would be great. Thanks!
pianofreq:
I read it as input select, which makes the suggestion to intercept the feed to the speakers redundant.
Maybe you can find a service manual for the speakers (at the Roland site?) and find out how the switch is connected.
You might then be able to replace it with a relay.
Would it be silly to ask why someone with a degree in Electrical Engineering wouldn't remove the six screws
to look at the switch to see if it is really a DPDT or simply an SPST used to pull a uC input low ?
