Lİneer actuator relay not responding
Hi all
I actually had requested help for my project in which I am using an RF433 remote to control extension and retraction of a lineer actuator through a relay. Unfortunately not quite a bit came out of it. Anyway
So here is my much simplified version of this set up. There are two buttons on my remote: A & B. A is used to move the actuator (both extend & retract) and B is used in urgent moments to stop the actuator. So there is no time limit, no states, whatsoever.
But somehow the relay does not respond to the remote. When I upload the code; the lights of respective lines are switched correctly. Thus no problem about initialization I guess. But I could not figure it out why it doesnt respond. Any help is highly appreciated. Below is my code:
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
int moveCommand = -7647;  // Command value for opening the door
int stopCommand = -7646;  // Command value for stopping the door
const int relayOpenPin = 8;  // Relay to open the door
const int relayClosePin = 10; // Relay to close the door
  mySwitch.enableReceive(0);  // Receiver on interrupt 0 => that is pin #2
  pinMode(relayOpenPin, OUTPUT);
  pinMode(relayClosePin, OUTPUT);
  digitalWrite(relayOpenPin,LOW);
  digitalWrite(relayClosePin,HIGH);
  if (mySwitch.available())
    int receivedData = mySwitch.getReceivedValue();
    mySwitch.resetAvailable();
    Serial.println(receivedData);
    if (receivedData==moveCommand && relayOpenPin==LOW && relayClosePin==HIGH){
      // opening
      digitalWrite(relayClosePin,LOW);
      digitalWrite(relayOpenPin,HIGH);
      else if (receivedData==stopCommand && relayOpenPin==HIGH && relayClosePin==LOW) {
      // Interrupted opening
      digitalWrite(relayOpenPin, HIGH);
      digitalWrite(relayClosePin, HIGH);
      else if (receivedData==moveCommand && relayOpenPin==HIGH && relayClosePin==HIGH) {
      // Restart opening
      else if (receivedData==moveCommand && relayOpenPin==HIGH && relayClosePin==LOW) {
      // Closing
      else if (receivedData==stopCommand && relayOpenPin==LOW && relayClosePin==HIGH) {
      // Interrupted closing
      digitalWrite(relayOpenPin, LOW);
      digitalWrite(relayClosePin, LOW);
      else if (receivedData==moveCommand && relayOpenPin==LOW && relayClosePin==LOW) {
      // Restart closing
