Lines Of Code I Can't Seem To Fix
I’m using this program to make Arduino act as a switch. I will be using an external pulse on the input (Button 1-4) to activate the the outputs (LED 1-4) So a pulse to say input 4 will turn on output 4, another pulse to input 4 will turn output 4 off. This is suppose to have a De-bouncing section and this is where everything stops. While running the debugger I have all lines fixed except under loop section, the “if” statement and it says <“old_val not declared in this scope” > I have searched on the forum and have not found anything about this. This is basically the first few lessons in learning Arduino tutorial. I have never programmed before so this is kicking my butt.
Thanks
Greg
#define LED_1 2
#define LED_2 3
#define LED_3 4
#define LED_4 5
// Channel 1-4 Output
#define BUTTON_1 6
#define BUTTON_2 7
#define BUTTON_3 8
#define BUTTON_4 9
// Channel 1-4 Input
int val = 0;
// val will be used to store the state
// of the input pin
//int old_val = 0;
// this variable stores the previous
// value of "val"
int state = 0;
// 0 = LED off and 1 = LED on
  pinMode(LED_1, OUTPUT);
  pinMode(LED_2, OUTPUT);
  pinMode(LED_3, OUTPUT);
  pinMode(LED_4, OUTPUT);
  // tell Arduino LED is an output
  pinMode(BUTTON_1, INPUT);
  pinMode(BUTTON_2, INPUT);
  pinMode(BUTTON_3, INPUT);
  pinMode(BUTTON_4, INPUT);
  //tell Arduino BUTTON in an input
void loop(){
  val = digitalRead(BUTTON_1);
  val = digitalRead(BUTTON_2);
  val = digitalRead(BUTTON_3);
  val = digitalRead(BUTTON_4);
// read input value and store it
// check if there was a transition
  if ((val == HIGH) && (old_val == LOW)){
    state = 1 - state;
    delay(10);
  old_val = val;
  // val is now old, let's store it
  if (state == 1) {
    digitalWrite(LED_1, HIGH);
    digitalWrite(LED_2, HIGH);
    digitalWrite(LED_3, HIGH);
    digitalWrite(LED_4, HIGH);
    // turn LED ON
  else {
    digitalWrite(LED_1, LOW);
    digitalWrite(LED_2, LOW);
    digitalWrite(LED_3, LOW);
    digitalWrite(LED_4, LOW);
    // turn LED OFF
//int old_val = 0;
That was easy.
AWOL: //int old_val = 0;
That was easy.
So does this replace the if statement?
Greg
// comments out everything following it on a line so
//int old_val = 0; is treated as a COMMENT!
you want
int old_val = 0;
No, your "declaration" of "old_val" is inside a comment, so isn't seen by the compiler. Revoce the "//"
OK I see it now. I read over it several times before I saw it. Its is now complied so I'll load it and see if it works.
Thanks Greg
You're going have to look at why this doesn't work next.
Been there. Done that!
My son in law is a programmer but I'm trying to do this without his help because he is to busy now without me adding to it. But I did tell him about this and he said their are programs available that will compare 2 different files so You can see the differences. Anyone used these?
Greg
I use BeyondCompare, but there are plenty of others
I use Textpad on Windows (at work), and it has a compare files option which works pretty well. On *nix systems, I just use diff.
Well the program compiled and loaded but does not work and don't have a clue as to why. The only different from the original program is I added more inputs and outputs. Any suggestions?
Thanks Greg
#define LED_1 2
#define LED_2 3
#define LED_3 4
#define LED_4 5
#define BUTTON_1 6
#define BUTTON_2 7
#define BUTTON_3 8
#define BUTTON_4 9
int val = 0;
// of the input pin
int old_val = 0;
// value of "val"
int state = 0;
void loop(){
    state = 1 - state;
    delay(10);
  //old_val = val;
  if (state == 1) {
    // turn LED ON
  else {
    // turn LED OFF
See reply #6
After looking at the reference I think its not working because “val=digitalRead(BUTTON_1)” also needs to “digitalWrite(ledPin, val); // sets the LED to the button’s value”
May be
Well after reading further I see digitalWrite will make the pin go high or low.
Greg
Look at it this way
val = 1;
val  = 0;
val = 1;
val  = 0;
What does val contain now?
val contains no value just digitalread the button.
Wrong. The digitalRead() function returns a value - the state of the switch (HIGH or LOW).
If you read 4 times, val contains the result of the last read, and only the last read.
PaulS:
So how do I get it to read each switch?
Greg
Just like you are doing. You just need to store the return code in four variables, not one.
