Hi everybody,
I would like to receive some help for my code for my arduino uno project, because it isn't working properly. Which involves 3 linetracker sensors, one ultrasonic sensor (HC-SRO4), two DC motors and a L298N Motor driver board. It is supposed to follow a black line and stop when an object is detected. The linetracking code by itself runs properly, however, when I add the obstacle detection code to it, the arduino fails to follow the black line, but the robot does stop when it detects an object. I hope someone can help me.
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
#define LT1 digitalRead(10)// linetracker 1
#define LT2 digitalRead(4)// linetracker 2
#define LT3 digitalRead(2)// linetracker 3
int M1 = 6; // right motor forward
int M2 = 7;// right motor back
int M3 = 8;// left motor back
int M4 = 9;// left motor forward
int ENA = 5; // motor left
int ENB = 11;// motor right
int ABS = 115;// speed
int middle_distance = 0;
int stop_distance = 12;
int Echo = A4; // ultrasonic sensor
int Trig = A5; // ultrasonic sensor
void forward(){
analogWrite(ENA, ABS);
analogWrite(ENB, ABS);
digitalWrite(M1, HIGH);
digitalWrite(M2, LOW);
digitalWrite(M3, LOW);
digitalWrite(M4, HIGH);
void back(){
digitalWrite(M1, LOW);
digitalWrite(M2, HIGH);
digitalWrite(M3, HIGH);
digitalWrite(M4, LOW);
void left(){
void extremeleft(){
void right(){
void extremeright(){
void stop(){
digitalWrite(ENA, LOW);
digitalWrite(ENB, LOW);
int Distance_test()
digitalWrite(Trig, LOW);
delayMicroseconds(2);
digitalWrite(Trig, HIGH);
delayMicroseconds(20);
float Fdistance = pulseIn(Echo, HIGH);
Fdistance= Fdistance/58.2;
return (int)Fdistance;
void setup(){
myservo.attach(3);
pinMode(Echo, INPUT);
pinMode(Trig, OUTPUT);
pinMode(M1,OUTPUT);
pinMode(M2,OUTPUT);
pinMode(M3,OUTPUT);
pinMode(M4,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(ENB,OUTPUT);
myservo.write(90);
middle_distance = Distance_test();
if (middle_distance<=stop_distance)
stop();
else if(LT1 == 0 && LT2 == 1 && LT3 == 0){
forward();
else if(LT1 == 1 && LT2 == 0 && LT3 == 0) {
extremeleft();
while(LT1);
else if (LT1 == 1 && LT2 == 1 && LT3 == 0){
left();
while (LT1 && LT2);
else if(LT3) {
extremeright();
while(LT3);
else if (LT1 == 0 && LT2 == 1 && LT3 == 1){
right();
while(LT2 && LT3);
