Linino, Enable and Disable wifi!
Hi, i need to know the linino command to enable and disable the wlan because i need to save the battery that i use for my Yun. Thanks!
If it's temporary, run "wifi down" from linux If it's permanent, follow these instructions http://forum.arduino.cc/index.php?topic=188821.msg1399080#msg1399080
Thanks, and for the reactivation ? I need to disable for a 30 min reacativate for 5 min and then deacativate again!
I don't remember if it's wifi up or just wifi, you have to try by yourself
Thanks! I've solved!
Stefanodal74: Thanks! I've solved!
And how? Would you mind sharing with the community?
