Is the watchdog on Linino active by default ? If it is, does this means it will automatically reboot if Linino freezes for any unforeseen reason ?
Thanks in advance!
Thanks in advance!
Yes.
ls /dev/watchdog -al
crw-r--r-- 1 root root 10, 130 Mar 9 08:50 /dev/watchdog
means hardware driver is loaded
ps |grep watchdog
861 root 1504 S /sbin/watchdog -t 5 /dev/watchdog
2179 root 1496 S grep watchdog
means service is started.
killall -9 watchdog
testing watchdog, if after few second Yun is reboot then watchdog is working.
Thanks sonnyyu,
I was reading that the 32u4 also has a "watchdog" that can be setup.
Do you know if the watchdog on the 32u4 side is reseted at startup (so it does not get caught up in an infinite "booting" loop).
I found this post about it: Watchdog in Arduino Library - or at least support by bootloader - #58 by system - Project Guidance - Arduino Forum
But have not found a definite answer yet...
Thanks again,
sonnyyu:
Yes.ls /dev/watchdog -al
means hardware driver is loadedps |grep watchdog
2179 root 1496 S grep watchdogmeans service is started.killall -9 watchdog
bilica:
No, 32u4 side is not reseted at linono reboot.
You need reset it by yourself.
nano /etc/rc.local
/usr/bin/reset-mcu
wifi-live-or-reset
exit 0
Sorry sonnyyu, I did not expressed myself properly.
I meant the AVR command:
wdt_enable(WDTO_8S);
and
wdt_reset();
I would like to know if, on reboot, the 32u4 will remove the wdt_enable() command (so it prevents from going into an undesirable infinite loop of reboots).
Thanks
sonnyyu:
bilica:
...No, 32u4 side is not reseted at linono reboot.
nano /etc/rc.local/usr/bin/reset-mcu
wifi-live-or-reset
exit 0
You might post it at Using Arduino :: Microcontrollers forum?
Thanks I will try there - although I have already tried Arduino Forum :: Using Arduino :: Project Guidance
[Project Guidance - Arduino Forum
sonnyyu:
