Link ECU data display
Hi to all,
So for the last couple of weeks I have been working with a 2 line lcd and an uno. I have a aftermarket ecu in my car and all is working well with is no issues there. i created a can cable and terminated it and setup the CAN read demo. After looking at the data structure I feel that I have a pretty good handle on the data structure and its format, I think/though, not sure though. lol I have some values showing on the screen and its working for 3 parameters that I want to display but when i try to add a 4th output into position/byte 0 it stop updating values and leaves the last messages/values on the screen, If if move this message or delete the parameter added to byte 0 is proceeds updating again.
I am not sure what seems to be causing this but maybe someone can give me a hand
using a sparkfun mcp2515 can shield. I have attached the .zip if anyone want to down load and take a look.
if this is confusing let me know and I will try to explain better if I can.
vi-pec_display.zip (130 KB)
Many members are reluctant to download unknown zip files. You will have better luck getting answers if you post the code as described in the "how to use this forum-please read" stickies. Post links to libraries that do not come with the IDE.
The easier that you make it for us to help you, the more help you will get.
