Link multiple address PZEM to Blynk
I make a code that can read all the value of PZEM with shared pins. I can print it on serial command and get the value. The problem is that I don't know how to send this data to Blynk
This is my code:
#include <PZEM004Tv30.h>
#if !defined(PZEM_RX_PIN) && !defined(PZEM_TX_PIN)
#define PZEM_RX_PIN D5
#define PZEM_TX_PIN D6
#endif
#if !defined(PZEM_SERIAL)
#define PZEM_SERIAL Serial2
#endif
#define NUM_PZEMS 6 // Number PZEM used
PZEM004Tv30 pzems[NUM_PZEMS];
#define USE_SOFTWARE_SERIAL
#include <SoftwareSerial.h>
SoftwareSerial pzemSWSerial(PZEM_RX_PIN, PZEM_TX_PIN);
    // For each PZEM, initialize it
    for(int i = 0; i < NUM_PZEMS; i++)
        // Initialize the PZEMs with Software Serial
        pzems[i] = PZEM004Tv30(pzemSWSerial, 0x10 + i);
    // Print out the measured values from each PZEM module
    for(int i = 0; i < NUM_PZEMS; i++){
        // Print the Address of the PZEM
        Serial.print("PZEM ");
        Serial.print(i+1);
        Serial.print(" - Address:");
        Serial.println(pzems[i].getAddress(), HEX);
        Serial.println("===================");
        // Read the data from the sensor
        float voltage = pzems[i].voltage();
        float current = pzems[i].current();
        float power = pzems[i].power();
        float energy = pzems[i].energy();
        float frequency = pzems[i].frequency();
        float pf = pzems[i].pf();
        // Check if the data is valid
        if(isnan(voltage)){
            Serial.println("Error reading voltage");
        } else if (isnan(current)) {
            Serial.println("Error reading current");
        } else if (isnan(power)) {
            Serial.println("Error reading power");
        } else if (isnan(energy)) {
            Serial.println("Error reading energy");
        } else if (isnan(frequency)) {
            Serial.println("Error reading frequency");
        } else if (isnan(pf)) {
            Serial.println("Error reading power factor");
            // Print the values to the Serial console
            Serial.print("Voltage: ");      Serial.print(voltage);      Serial.println("V");
            Serial.print("Current: ");      Serial.print(current);      Serial.println("A");
            Serial.print("Power: ");        Serial.print(power);        Serial.println("W");
            Serial.print("Energy: ");       Serial.print(energy,3);     Serial.println("kWh");
            Serial.print("Frequency: ");    Serial.print(frequency, 1); Serial.println("Hz");
            Serial.print("PF: ");           Serial.println(pf);
        Serial.println("-------------------");
    delay(2000);
This code came from the example inside arduinoIDE "PZEMMultipleDevice". Please help me so I can send this data to Blynk
