Linking 2 Arduinos over ethernet
How are you guys!
Anyone can make this topic (Linking 2 Arduinos over ethernet - Programming Questions - Arduino Forum) compile in 2013?
Today I'm using to comunicating with my webserver:
EthernetServer server(8081);
EthernetClient client;
client = server.available();
if(client){
for(int i = 0; client.available() > 0; i++)
msg = client.read();
client.write(buffer);
Very simple code! A want to creat a code in another Arduino to comunicate with this code it's already working with webserver... I want my first arduino to comunicate with webserver or with another arduino, without notice... but I don't know how... I tried but didn't worked...
This client and server code should work together.
http://playground.arduino.cc/Code/WebClient
http://playground.arduino.cc/Code/WebServerST
Use the GET request on the client code. Note the warnings about the mac addresses of each device. They must all be unique.
That would have been one of the problems with the sketches zoomkat suggested on the other topic. My code in the playground had the same problem, but you will notice the mac addresses are not identical on my client and server code.
I'll try, but I think this code is very complex compared to my code that only uses:
msg[ i ] = client.read; in the arduino side and
$sock = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
socket_connect($sock,$arduinoip, 8081);
socket_write($sock,'R',1);
$status = socket_read($sock,50);
in web side
Is there any "socket_connect" in the Ethernet lib?
You will need a server. It does not have to stick to strict format data. The client can send what you want. The server can return what you want.
If you want http format and fault tolerance, then what you see there is the minimum for continued operation. Otherwise it would be what I refer to as "perfect world" code. It works as long as nothing goes wrong. The bad news is that things go wrong often, so if not written with built-in fault tolerance, your code will lock up often.
First I want a easy and simple read/write, than I want a bullet proof code...
Have you considered UDP? That is about as simple as it gets. No connection or error checking at all. Just send the packet. It isn't bulletproof. You never know if the packet got there or not unless the destination device sends a response packet back to you.
The UDP "server" sends packets to its "clients", and the "client" send a response packet to the server.
edit: Or the other way around if you wish. Client initiates a packet, server responds.
Not sure what is being requested, but the below code has both web client and web server functions. A client request can be sent via the serial monitor, and when connected to from a browser client a web page is served up with some control buttons that cause action on the arduino.
//zoomkat 7-03-12, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pins high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
char serverName[] = "web.comporium.net"; // (DNS) zoomkat's test web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  pinMode(6, OUTPUT); //pin selected to control
  pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
  //pinMode(5, OUTPUT); //pin 5 selected to control
  Ethernet.begin(mac,ip,gateway,gateway,subnet);
  server.begin();
  Serial.println("server/client 1.0 test 7/03/12"); // keep track of what is loaded
  Serial.println("Send an g in serial monitor to test client"); // what to do to test client
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call client sendGET function
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.print(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println(F("HTTP/1.1 204 Zoomkat"));
            client.println();
            client.println();
          else {
            client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
            client.println(F("Content-Type: text/html"));
            client.println();
            client.println(F("<HTML>"));
            client.println(F("<HEAD>"));
            client.println(F("<TITLE>Arduino GET test page</TITLE>"));
            client.println(F("</HEAD>"));
            client.println(F("<BODY>"));
            client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
            // DIY buttons
            client.println(F("Pin5"));
            client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
            client.println(F("Pin6"));
            client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
            client.println(F("Pin7"));
            client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
            client.println(F("Pin8"));
            client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
            client.println(F("Pins"));
            client.println(F("&nbsp;<a href=/?off2468 target=inlineframe>ALL ON</a>"));
            client.println(F("&nbsp;<a href=/?off3579 target=inlineframe>ALL OFF</a>"));
            client.println(F("<IFRAME name=inlineframe style='display:none'>"));
            client.println(F("</IFRAME>"));
            client.println(F("</BODY>"));
            client.println(F("</HTML>"));
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') >0)//checks for 2
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led 5 On");
          if(readString.indexOf('3') >0)//checks for 3
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led 5 Off");
          if(readString.indexOf('4') >0)//checks for 4
            digitalWrite(6, HIGH);    // set pin 6 high
            Serial.println("Led 6 On");
          if(readString.indexOf('5') >0)//checks for 5
            digitalWrite(6, LOW);    // set pin 6 low
            Serial.println("Led 6 Off");
          if(readString.indexOf('6') >0)//checks for 6
            digitalWrite(7, HIGH);    // set pin 7 high
            Serial.println("Led 7 On");
          if(readString.indexOf('7') >0)//checks for 7
            digitalWrite(7, LOW);    // set pin 7 low
            Serial.println("Led 7 Off");
          if(readString.indexOf('8') >0)//checks for 8
            digitalWrite(8, HIGH);    // set pin 8 high
            Serial.println("Led 8 On");
          if(readString.indexOf('9') >0)//checks for 9
            digitalWrite(8, LOW);    // set pin 8 low
            Serial.println("Led 8 Off");
          //clearing string for next read
          readString="";
void sendGET() //client function to send and receive GET data from external server.
  if (client.connect(serverName, 80)) {
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
  else {
    Serial.println("connection failed");
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    Serial.print(c);
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop();
zoomkat, can you take a look in my other topic?
http://forum.arduino.cc/index.php?topic=172721.0
Thank you
jgarcia:
Is there a similar "socket_connect" to Arduino? - Networking, Protocols, and Devices - Arduino Forum
Thank you
I looked at your other topic, so do you have a question about this current topic?
