Linking Large Font to Variable
Hi Everyone,
I found this great example of how to create large fonts for a 16x2 lcd, but I can’t figure out how to link the large font to a variable. Here’s the code for generating larger than life numbers. It displays the large font and scrolls each number across the screen. Can anyone point me to information on how to link the custom characters to a variable?
Thanks for the help!
A set of custom made large numbers for a 16x2 LCD using the
 LiquidCrystal librabry. Works with displays compatible with the
 Hitachi HD44780 driver.
 The Cuicuit:
 LCD RS pin to D7
 LCD Enable pin to D6
 LCD D4 pin to D5
 LCD D5 pin to D4
 LCD D6 pin to D3
 LCD D7 pin to D2
 LCD Vee tied to a pot to control brightness
 LCD Vss and R/W tied to ground
 LCD Vcc to +5V
 LCD pin 15 tied to pushbutton for control of backlight
 Made by Michael Pilcher
 2/9/2010
// include the library
#include <LiquidCrystal.h>
// initialize the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int x = 0;
// the 8 arrays that form each segment of the custom numbers
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
  // assignes each segment a write number
  lcd.createChar(8,LT);
  lcd.createChar(1,UB);
  lcd.createChar(2,RT);
  lcd.createChar(3,LL);
  lcd.createChar(4,LB);
  lcd.createChar(5,LR);
  lcd.createChar(6,UMB);
  lcd.createChar(7,LMB);
  // sets the LCD's rows and colums:
  lcd.begin(0, 2);
void custom0O()
{ // uses segments to build the number 0
  lcd.setCursor(x, 0);
  lcd.write(8);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x, 1);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1,1);
  lcd.write(255);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.setCursor(x+2, 1);
  lcd.write(255);
void custom5()
  lcd.setCursor(x,0);
  lcd.write(255);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write(8);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1, 1);
  lcd.write(8);
void custom8()
  lcd.setCursor(x,0);
  lcd.write(8);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write(8);
  lcd.write(6);
  lcd.write(2);
  lcd.write(255);
void numbers()
  custom0O();    // displays custom 0 on the LCD
  x = x + 4;    // sifts cursor over 4 columns
  custom1();
  x = x + 4;
  custom2();
  x = x + 4;
  custom3();
  x = x + 4;
  custom4();
  x = x + 4;
  custom5();
  x = x + 4;
  custom6();
  x = x + 4;
  custom7();
  x = x + 4;
  custom8();
  x = x + 4;
  custom9();
  x = 0;
  lcd.clear();
  numbers();
  for (int positionCounter = 0; positionCounter < 24; positionCounter++) {
    lcd.scrollDisplayLeft();
  x = 0;
  lcd.clear();
