I got a pair of 434mhz rf link transmitter and receiver and I have gone through several examples but I am not getting it to communicate. I was wondering if you could guide me if I am doing something wrong.
As per my circuit:
I have receiver pin 1 connect to Ground, pin 2 to digital pin 2 (for data in) of arduino, and pin 4 to power (5v). And I have an led connected to pin 11 for debugging purposes.
For the transmitter:
I have pin1 connected to Ground, pin2 to digital pin 4, and pin 3 to power(5v).
As per my code I have tried using Virtual wire library but I have not been getting any response on the receiver side.
So I just tried using NewSoftSerial library but that too has not worked.
Basically the transmitter is simply sending a sentence as char type to receiver and I have a if() statement on the receiver end which will turn on the LED if there is data on serial port. But instead LED comes on anyways.
At first glance, it seems like a programming error, but if I take out the rf receiver, the LED goes off and upon plugging receiver back the LED comes on. But if I take out the transmitter the LED still stays on.
Also the rx light on the receiver end should come on when receiving data but it isn't. Neither is the tx light on the transmitter end.
I have attached my receiver & transmitter codes in here, if someone would like to take a look.
In the attached files: receiveSoft & transmitSoft use NewSoftSerial library and receivevw & transmitvw use Virtual wire library.
To me it seems like the transmitter is not functioning,
I appreciate any help.
receiverSoft.pde (705 Bytes)
transmitterSoft.pde (267 Bytes)
receivervw.pde (918 Bytes)
transmittervw.pde (469 Bytes)
