Hi there,
I have a Serial camera which I connected to my Arduino using the following code:
byte incomingbyte;
int a=0x0000,j=0,k=0,count=0; //Read Starting address
uint8_t MH,ML;
boolean EndFlag=0;
void SendResetCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
Serial.begin(38400);
Serial1.begin(38400);
SendResetCmd();
delay(4000); //After reset, wait 2-3 second to send take picture command
SendTakePhotoCmd();
while(Serial1.available()>0)
incomingbyte=Serial1.read();
byte a[32];
while(!EndFlag)
j=0;
k=0;
count=0;
SendReadDataCmd();
delay(25);
k++;
if((k>5)&&(j<32)&&(!EndFlag))
a[j]=incomingbyte;
if((a[j-1]==0xFF)&&(a[j]==0xD9)) //Check if the picture is over
EndFlag=1;
j++;
count++;
for(j=0;j<count;j++)
{ if(a[j]<0x10)
Serial.print("0");
Serial.print(a[j],HEX);
Serial.print(" ");
} //Send jpeg picture over the serial port
while(1);
//Send Reset command
void SendResetCmd()
Serial1.write(0x56);
Serial1.write(0x00);
Serial1.write(0x26);
//Send take picture command
Serial1.write(0x36);
Serial1.write(0x01);
//Read data
MH=a/0x100;
ML=a%0x100;
Serial1.write(0x32);
Serial1.write(0x0c);
Serial1.write(0x0a);
Serial1.write(MH);
Serial1.write(ML) ;
Serial1.write(0x20);
a+=0x20;
Serial1.write(0x03);
By using this code I get hexadecimal numbers. The problem is that I can't convert these hexadecimal numbers into a jpeg file. What's pretty weird is that a jpeg file always starts with "FF D8", but there is no "FF D8" in my data. Is there any mistake?
camera data.txt (36.5 KB)
