Linrose Superbrite RGB LED - 3 legs
I've got an Arduino UNO.
I've seen tutes for two legs and four legs, but not 3 legs.
Specifically the breadboard, the pins, and the coding..
This looks like a comparable model if it helps:
I've also got specs from the package.
More info:
Thanx
I might add, I'm an arduino newbie but, I also own a raspberry pi and beaglebone black, so, I'm
not entirely new, just largely a novice in this area.
Thanx
OK, there are a number of different things here.
The "Red/Green/Amber" LED is in fact a simple two colour LED - amber or yellow is what you get adding red to green - as it is in a RGB LED anyway.
There are as in the "instructables" answers, LEDs which contain sequencers which can be controlled to some degree by a third pin.
And the LED in the youtube video may be a rather odd "Charlieplexed" one which has the three elements connected in a circular sequence. Mind you I could only see two colours in the video anyway.
Your amazon link is:
I haven't followed so I could be wrong but "Green Amber Tricolor" isn't the same as RGB.
fungus:
http://www.amazon.com/Linrose-B4361H1-Green-Amber-Tricolor/dp/B008K1SWEC
Duh. Good point.
Burned on two levels.
Maybe I'll just go get a proper "RGB" LED.
