Linux 64 bit support
I'm running Fedorda 9 64 bit Linux. I installed version 0013 and ran into a some problems, a couple of which I solved:
  • Wrong architecture for RXTX.
I installed rxtx-2.1-0.2.7r2.fc9.x86_64.rpm and set the CLASSPATH:
CLASSPATH=/usr/share/java/RXTXcom.jar
and renamed lib/librxtxSerial.so. /usr/lib64/rxtx/librxtxSerial.so is used instead.
  • Unable to open USB device.
Added myself to uucp group so I could open /dev/ttyUSB0
This works fine for a moderndevice.com bare bones board.
I have two problems with a Duemilanove board. First, if I select a board type of 'Arduino Diecimilla or Duemilanove', it uses the wrong baud rate. From playing with the 'Serial Monitor, it should be 38400. Instead it uses 19200. I tried setting the rate in ~/.arduino/preferences.txt
serial.download_rate=38400
serial.debug_rate=38400
But it always uses 19200, as seen in the avrdude command line:
hardware/tools/avrdude -Chardware/tools/avrdude.conf -v -v -v -v -pm168 -cstk500v1 -P/dev/ttyUSB0 -b19200 ....
If I set the board type to 'Aruduino w/ ATmega328', I get a link error:
/usr/lib/gcc/avr/4.3.3/../../../../avr/bin/ld: crtm328p.o: No such file: No such file or directory
I have avr-libc-1.6.4-1.fc9.noarch installed. There are no crt328.o files at all.
Any ideas?
I believe you should set the baud rate in the boards.txt file. Path should be pathtoarduinofolder/hardware/boards.txt
Sorry, can't help with the avr-libc bit as I'm using Ubuntu and recompiled the whole avr-gcc toolchain myself to ensure I had the latest versions.
HTH
Ver
