Linux C serial communication with arduino
Hello, I have been spending many days searching for a c program on Linux which will “talk” to the Arduino via the virtual serial. I have found many which look promising but i could not implement. I found one earlier on today and it seems to be the key.
After deciphering through both Arduino code and c code i changed some of the Arduino code to SEE it worked. IT DID / NOT WORK. This is where I need help.
This is my Arduino code:
int val = 0;
char response[20];
  pinMode(13, OUTPUT);
void loop () {
  if (Serial.available() ) {
    int dataCounter = 0;
    while((val = Serial.read()) != ':') {
      if(val!= -1) {
        response[dataCounter] = val;
        ++dataCounter;
    processData();
    response[dataCounter] = ':';
    response[dataCounter+1] = '\0';
    Serial.println(response);
void processData() {
  if(response[0] == 'f') {
      digitalWrite(13,HIGH);
      Serial.println("off");
      digitalWrite(13,LOW);
This is the c program
 * Arduino-serial
 * A simple command-line example program showing how a computer can
 * communicate with an Arduino board. Works on any POSIX system (Mac/Unix/PC)
 * Compile with something like:
 * gcc -o arduino-serial arduino-serial.c
 * Created 5 December 2006
 * Copyleft (c) 2006, Tod E. Kurt, tod@todbot.com
 * Updated 8 December 2006:
 *  Justin McBride discoevered B14400 & B28800 aren't in Linux's termios.h.
 *  I've included his patch, but commented out for now.  One really needs a
 *  real make system when doing cross-platform C and I wanted to avoid that
 *  for this little program. Those baudrates aren't used much anyway. :)
 * Updated 26 December 2007:
 *  Added ability to specify a delay (so you can wait for Arduino Diecimila)
 *  Added ability to send a binary byte number
#include <stdio.h>    /* Standard input/output definitions */
#include <stdlib.h>
#include <stdint.h>   /* Standard types */
#include <string.h>   /* String function definitions */
#include <unistd.h>   /* UNIX standard function definitions */
#include <fcntl.h>    /* File control definitions */
#include <errno.h>    /* Error number definitions */
#include <termios.h>  /* POSIX terminal control definitions */
#include <sys/ioctl.h>
#include <getopt.h>
void usage(void);
int serialport_init(const char* serialport, int baud);
int serialport_writebyte(int fd, uint8_t b);
int serialport_write(int fd, const char* str);
int serialport_read_until(int fd, char* buf, char until);
void usage(void) {
    printf("Usage: arduino-serial -p <serialport> [OPTIONS]\n"
    "\n"
    "Options:\n"
    "  -h, --help                   Print this help message\n"
    "  -p, --port=serialport        Serial port Arduino is on\n"
    "  -b, --baud=baudrate          Baudrate (bps) of Arduino\n"
    "  -s, --send=data              Send data to Arduino\n"
    "  -r, --receive                Receive data from Arduino & print it out\n"
    "  -n  --num=num                Send a number as a single byte\n"
    "  -d  --delay=millis           Delay for specified milliseconds\n"
    "\n"
    "Note: Order is important. Set '-b' before doing '-p'. \n"
    "      Used to make series of actions:  '-d 2000 -s hello -d 100 -r' \n"
    "      means 'wait 2secs, send 'hello', wait 100msec, get reply'\n"
    "\n");
int main(int argc, char *argv[])
    int fd = 0;
    char serialport[256];
    int baudrate = B115200;  // default
    char buf[20], dat[20], use[1];
    int rc,n;
      //baudrate = 9600;
      fd = serialport_init("/dev/ttyACM0", baudrate);
                  if(fd==-1) return -1;
      usleep(3000 * 1000 );
      while(1) {
            strcpy(dat, "00000000:\0");
            gets(use);
            if(use[0] == 'i') {
                  dat[0] = 'f';
                  dat[1] = 5;
            else if(use[0] == 'k') {
                  dat[0] = 'b';
                  dat[1] = 5;
            else if(use[0] == 'j') {
                  dat[2] = 'f';
                  dat[3] = 5;
            else if(use[0] == 'l') {
                  dat[2] = 'b';
                  dat[3] = 5;
            rc = serialport_write(fd, dat);
                        if(rc==-1) return -1;
             //printf("Waiting until UART buffer clears: %d\n", tcdrain(fd));
             n = serialport_read_until(fd, buf, ':');
               printf("wrote %d bytes, read %d bytes: %s\n", rc, n, buf);
       close(fd);
    exit(EXIT_SUCCESS);
} // end main
int serialport_writebyte( int fd, uint8_t b)
    int n = write(fd,&b,1);
    if( n!=1)
        return -1;
    return 0;
    int len = strlen(str);
    int n = write(fd, str, len);
    if( n!=len )
        return -1;
    return n;
    char b[1];
    int i=0;
    do {
        int n = read(fd, b, 1);  // read a char at a time
        if( n==-1) return -1;    // couldn't read
        if( n==0 ) {
            usleep( 10 * 1000 ); // wait 10 msec try again
            continue;
        buf[i] = b[0]; i++;
    } while( b[0] != until );
    buf[i] = 0;  // null terminate the string
    return i;
// takes the string name of the serial port (e.g. "/dev/tty.usbserial","COM1")
// and a baud rate (bps) and connects to that port at that speed and 8N1.
// opens the port in fully raw mode so you can send binary data.
// returns valid fd, or -1 on error
    struct termios toptions;
    int fd;
    //fprintf(stderr,"init_serialport: opening port %s @ %d bps\n",
    //        serialport,baud);
    //fd = open(serialport, O_RDWR | O_NOCTTY | O_NDELAY);
    fd = open(serialport, O_RDWR | O_NOCTTY);
    if (fd == -1)  {
        perror("init_serialport: Unable to open port ");
        return -1;
    if (tcgetattr(fd, &toptions) < 0) {
        perror("init_serialport: Couldn't get term attributes");
        return -1;
    speed_t brate = baud; // let you override switch below if needed
    switch(baud) {
    case 4800:   brate=B4800;   break;
    case 9600:   brate=B9600;   break;
// if you want these speeds, uncomment these and set #defines if Linux
//#ifndef OSNAME_LINUX
//    case 14400:  brate=B14400;  break;
//#endif
    case 19200:  brate=B19200;  break;
//    case 28800:  brate=B28800;  break;
//#endif
    //case 28800:  brate=B28800;  break;
    case 38400:  brate=B38400;  break;
    case 57600:  brate=B57600;  break;
    case 115200: brate=B115200; break;
    cfsetispeed(&toptions, brate);
    cfsetospeed(&toptions, brate);
    // 8N1
    toptions.c_cflag &= ~PARENB;
    toptions.c_cflag &= ~CSTOPB;
    toptions.c_cflag &= ~CSIZE;
    toptions.c_cflag |= CS8;
    // no flow control
    toptions.c_cflag &= ~CRTSCTS;
    toptions.c_cflag |= CREAD | CLOCAL;  // turn on READ & ignore ctrl lines
    toptions.c_iflag &= ~(IXON | IXOFF | IXANY); // turn off s/w flow ctrl
    toptions.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); // make raw
    toptions.c_oflag &= ~OPOST; // make raw
    // see: http://unixwiz.net/techtips/termios-vmin-vtime.html
    toptions.c_cc[VMIN]  = 0;
    toptions.c_cc[VTIME] = 20;
    if( tcsetattr(fd, TCSANOW, &toptions) < 0) {
        perror("init_serialport: Couldn't set term attributes");
        return -1;
    return fd;
When I open the arduino Serial and type in “f:” the LED turn on and i get the correct response. When I run it from c program I am not able to turn the LED on.
What I get is :
XPS:~/Desktop$ ./a.out
f:
wrote 9 bytes, read 14 bytes: off
00000000:
Thank you in advance
-manorios
I am using Arduino mega 2560 and Ubuntu 10.04LTS
This is there I got the original code
http://forums.trossenrobotics.com/tutorials/introduction-129/arduinocomputer-controlled-robot-2096/
You should declare use[1] to have more characters, and perhaps use fgets() to limit the number of characters to read.
You also do not handle the case when the first character is 'f'. You have:
if (use[0] == 'i') {
etc. but you do not have a case to check "if (use[0] == 'f')".
-- The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Thank you so much :) that fixed the problem i cannot believe I missed that.
i am trying to use fgets instead but I am not sure what to place in the third argument. i changed use to be 8 char.
fgets(use,8,???);
Thank you again -manorios
fgets(use, 8, stdin);
-- The Quick Shield: breakout all 28 pins to quick-connect terminals
