On Linux, if you have more than one USB tty device, the USB port name (/dev/ttyUSBx) changes every time one is plugged in... and there's no easy way to know the new name without going and looking through dmesg. It's trivial to set up a udev rule that creates a custom symlink so that my arduino's FTDI can always be accessed through (eg) /dev/ttyArduino, and this is the recommended procedure for persistent access to USB devices.
Basically this means you can use a symlink as long as it's /dev/tty* followed by a number between 0 and 999.
For example: if you'd symlink to ttyUSB901 it will show up in the Arduino IDE.
Raymond_Pl:
Same problem, , using numers in the symlink worked for me.
pity though that i can not use nice names as ttyUSB-nano andttyUSB-nodemcu etc,
that would be a lot more userfriendly.
