I have a new Linux install (Lubuntu) on an old Macbook. Under Linux, my Duemilanove sometimes won't work.
I am usually able to upload fine. But every once in a while, though, it won't upload... I'll get the "stk500_recv(): programmer is not responding" error. But not always! Once it happens, it may take 10-20min to work again. It seems sort of random (how long it takes to work again).
There is no specific program that this happens with -- it happens even with the Blink program, and even if nothing is plugged in at all. I have checked for shorts, etc. and can't seem to find any. I am not doing anything with pins 0/1.
One of of my first thoughts was that the bootloader was corrupted. So I reburned the bootloader. Still didn't work.
Then I tried replacing the ATmega (with a newly burned bootloader). Same problem persisted.
Yet I think the bootloader is fine because the pin 13 LED always blinks upon reset.
Then I thought it was probably the FTDI chip. But when I program on my iMac (w/ OSX), everything seems fine. I never get the error on my mac: only under Linux!
This wouldn't surprise me if it happened every time. But it happens intermittently. That wouldn't make sense if it was a driver / FTDI chip problem (after all, the board is 4+ years old).
While it is broken, the TX/RX LEDs don't blink as much as they should. A couple flashes of the TX light right after reset, and then nothing. This would seem to implicate the FTDI chip. Yet I never have problems with serial communication (i.e. Serial.prinln())... only upload causes problems.
I have not been able to figure out any other information (i.e. what triggers the problem, what causes it to work again).
So my questions are:
- Is this a Linux thing? Or was I just lucky enough to not see it while using my iMac?
- Could this be a problem with the FTDI chip?
- And should I just get a new arduino? Keep in mind this is a duemilanove... 4-5 years old.
- Could this be a USB port bad connection? I never see the power light flicker, but maybe the data lines have bad connections (on either the Arduino on computer end)? I have tried changing USB cables.
Thanks.
baum
