Despite following the instructions elsewhere on this forum for setting up a USB port to talk to my Diecimila, I'm still getting the serial port not found error. I can send/receive data from a command prompt in a terminal session, but nothing in or out when in the Arduino IDE. I've done a chmod and chown on it without success, too.
This is on a SuSE 11 box that does not have brltty installed (that I can find, anyway).
DMerriman: what device is the Arduino on? Did you select it from the Tools > Serial Port menu? Exactly what error do you get? When?
The Arduino is on ttyUSB0. I can send/receive from a command line, but the IDE never shows me a serial option of ttyUSB0 -- just ttyS0 (I have just one COM port, which has my Palm cradle [sans Palm] on it).
You might try editing your preferences file (in ~/.arduino/preferences.txt) and setting serial.port to /dev/ttyUSB0. Then run Arduino and try uploading. Also, if you have software that communicates with the Palm, you might try quitting it first, as it’s possible it’s scanning multiple serial ports.
---> the user MUST be a member of the UUCP group to make it work. I had the very same "error" (misconfiguration) !
---> this also affects several other dirs that are only writable for members of uucp (e.g. /var/lock/)
device files are created by UDEV every time you plug it in, so chmod chown will not help for long, and it is only a partial fix ( works for: echo "some text" >/dev/ttyUSB0 ). be sure to restart the X-session after you've put your user into the uucp group.
after that /dev/ttyUSB0 will appear in the IDE menu (Tools > Serial Port).
I had the cable for the Arduino plugged into a USB hub which was plugged into my system. When I finally unplugged the hub and plugged it back in again, everything started working the way it should.
I swear to FSM, computers are going to be the death of me....
Anyway, to all that answered and tried to help: [smiley=dankk2.gif]
