I have some questions regarding Lion or Lipo battery charging circuit design:
- I have read that if I want to charge a single cell, I need a two stage design. Constant Current until the cell reaches threshold charging voltage which is something like 4.2 +1% Volts or something (depending on the datasheet), and then Constant Voltage until the current reaches around 10% nominal current. I have learned this listening to the guy on EEEblog.
My Question is:
Can I treat a 3 cell series 12 Volt Lion battery like a single large battery and charge both anode and cathode of the big battery in Constant Current and Constant Voltage until the big battery reaches threshold charging voltage which is the single cell's threshold voltage times 3?
or is this bad practice, and I should be charging every cell individually?
- Must I use constant current and then constant voltage or, can I simply apply constant voltage and thats it.
- if I am applying constant voltage can I draw from the battery at the same time?
- do I need to smooth out battery voltage while drawing from the battery?
- how much maximum voltage can I charge with a USB connection, maximum current?
- do designers use IC's or do they just design all of their own stuff like constant current or step down circuites?
