Lipo battery chargers
I'm wondering about this module.
It has an in and an out where I assume in is from a solar panel or some other source. Alternatively in could also be used from a regulated micro USB source.
Then out is presumably to the battery but I'm wondering could I also use out to feed my Arduino?
https://images.google.hn/imgres?imgurl=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2F6x4AAOSw1DtXEaOs%2Fs-l300.jpg&imgrefurl=https%3A%2F%2Fwww.ebay.com%2Fitm%2F5V-Mini-USB-1A-Lithium-Battery-Charging-Module-Lipo-Charger-Module-for-Arduino-%2F122093110517&docid=kVhJcPhrYvZDtM&tbnid=E8hDxfjDIHiJtM%3A&vet=1&w=300&h=300&hl=en-US&source=sh%2Fx%2Fim
A specification would be a lot more use than just a picture. But generally battery chargers do not work as power supplies, their characteristics are completely different.
Steve
OK the description on Amazon is simply:
"5V Mini USB 1A Lithium Battery Charging Board Charger Module"
It is not a power supply it is a charger which takes 5V input from USB. The output charges a single Li-ion/Lipo battery to a maximum of 4.2V.
If you have a USB cable it will be much better to ignore that charger module and simply power the Arduino direct from the USB cable.
Steve
Well I was planning on using a solar panel to charge the lipo and run it autonomously
