LiPo battery to breadboard
Hi!
I have a 12V DC motor that draws about 0.4A. I have a 3S LiPo battery like this
Can I connect this LiPo battery to the breadboard or will it damage something? I'm controlling the motor with an L293D IC, that's why I would need it. Someone who has ever tried?
Thanks!
It will only damage something if there is a short circuit - and that could cause the battery to burst into flames.
In general it is not a good idea to pass large currents through a breadboard, but I think you will get away with 0.4 amps.
...R
Thanks!
Robin2:
I see. You know the problem is getting 12V from batteries (like AA or 4.5V bats) makes the vehicle way too heavy. But I have this LiPo at hand, which is light, that's why I would like to use it, I just don't know whether it's a good idea.
Place a fuse in the positive lead to protect your battery and board.
A 500mA or 1A fuse should be okay, depends on the stall current of the motor.
Tom.... :slight_smile:
PS. I recommend fuses for any Lipo or SLA battery application due to the massive short circuit currents that can be generated.
