I'm placing an Arduino project in a vehicle, and I need the project to run on a battery when the vehicle is off, but when the vehicle is on, I'd like to be charging the battery (and powering the project) via power/ground that I'll be bringing to the board (through an Adafruit DC/DC buck converter).
Will this product work for me?
Can I wire the vehicle (buck converter) +/- to the +/- terminals I see in the picture (right-hand side), and when the board is not getting power from the vehicle, will it switch over to using the battery automatically?
Thanks!
That device will provide 5V to your Arduino from a LiPo cell but it won't charge the LiPo cell.
Add this for charging the LiPo cell:
To that you need to add a 12V->5V regulator or DC-DC converter.
If you run an Arduino at 8 MHz you can run it directly off the LiPo cell, eliminating the need for the boost converter.
Thanks John!
If I swap out and use the produce you recommended, can I leave the battery plugged in at all times, and if the DC Input is present, it will automatically charge the battery, and when it's not, the battery will supply power to the Arduino?
If I have a 5V Adafruit Trinket (board with a 328P on it), and I clock_prescale to 8mhz, I won't need the booster?
Thanks!
