lipo state of charge determination
Hi, I am trying to build a fuel gauge for my Lipo batteries. I found few methods available such as voltage measurement, current measurement; however they are not reliable. I would like to know which methods and equipment you often prefer to determine the SOC of your battery. Since I am an arduino newbie, i will be glad if you can give me some info about connections and sample codes aswell.
Thank your for your help already.
My equipment:
Battery: http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6504
Arduino Duemilanove
You can use this to monitor the SOC
Stand-Alone Fuel-Gauge IC Calculates Remaining Battery Capacity
Stand-Alone Fuel Gauge That Integrates LED Display Drivers
Thanks for your fast reponse. I looked into the links that you have sent. These chips could be the answer to my problems, but I have this following question:
Since I am planning to integrate a wireless communication using Xbee Shield, the regular serial communication option would be occupied. I have checked some 1-Wire tutorials on Arduino playground from what i can tell the OneWire.h library given in playground uses the serial communication.
So can I adapt a one-wire communication to my project ? Does it require for serial communication pins "rx" "tx" to be vacant.
I will be glad if you can help me with the connections between the chip and arduino
one-wire communication using digital pin, not require for serial comm.
http://www.arduino.cc/playground/Learning/OneWire
