Hello I have downloaded what I think all the libaries, bbut now have some other problems.
would be great if soemone could help woth those errors. I have to say I’m really new into that. Sorry .
Thanks
Arduino: 1.6.5 (Windows 8.1), Board: “Arduino/Genuino Uno”
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library SD in folder: C:\Program Files (x86)\Arduino\libraries\SD
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library Arduino-LiquidCrystal-I2C-library-master in folder: C:\Program Files (x86)\Arduino\libraries\libraries\Arduino-LiquidCrystal-I2C-library-master (legacy)
Using library Time in folder: C:\Program Files (x86)\Arduino\libraries\libraries\Time (legacy)
Using library Ethernet in folder: C:\Program Files (x86)\Arduino\libraries\Ethernet
Using library pitches in folder: C:\Program Files (x86)\Arduino\libraries\libraries\pitches (legacy)
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\SD\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\libraries\Time -IC:\Program Files (x86)\Arduino\libraries\Ethernet\src -IC:\Program Files (x86)\Arduino\libraries\libraries\pitches C:\Users\Reinhard\AppData\Local\Temp\build1104042723699220277.tmp\NewVendingMachine3_8.cpp -o C:\Users\Reinhard\AppData\Local\Temp\build1104042723699220277.tmp\NewVendingMachine3_8.cpp.o
NewVendingMachine3_8.ino:15:53: error: ‘POSITIVE’ was not declared in this scope
NewVendingMachine3_8.ino: In function ‘void setup()’:
NewVendingMachine3_8.ino:91:18: error: no matching function for call to ‘LiquidCrystal_I2C::begin(int, int)’
NewVendingMachine3_8.ino:91:18: note: candidate is:
In file included from NewVendingMachine3_8.ino:4:0:
C:\Program Files (x86)\Arduino\libraries\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: void LiquidCrystal_I2C::begin()
void begin();
C:\Program Files (x86)\Arduino\libraries\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate expects 0 arguments, 2 provided
NewVendingMachine3_8.ino:121:3: error: ‘Serial1’ was not declared in this scope
NewVendingMachine3_8.ino: In function ‘void ReadyforRFID()’:
NewVendingMachine3_8.ino:256:11: error: ‘Serial1’ was not declared in this scope
NewVendingMachine3_8.ino: In function ‘void checkRFID()’:
NewVendingMachine3_8.ino:268:7: error: ‘Serial1’ was not declared in this scope
NewVendingMachine3_8.ino (28.9 KB)
