Liquid Crystal lib with IDE 1.5.4
I tried to test an LCD Keypad Shield from DFRobot with the Liquid Crystal lib and IDE 1.5.4
It seems that
LiquidCrystal lcd(8, 9, 4, 5, 6, 7)
does not work.
Any hints whats wrong?
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
This program will test the LCD panel
Mark Bramwell, July 2010
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
 lcd.begin(16, 2);              // start the library
 lcd.setCursor(0,0);
 lcd.print("Hello World"); // print a simple message
 lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
 lcd.print(millis()/1000);      // display seconds elapsed since power-up
Have you also tried it with another IDE? just to check if your LCD is working or that it is the LCD lib?
What model is your LCD?
What model is your arduino? (Mega, Uno, Due, etc.)
There are many LCD libraries, and they are not all created equal. Also not all LCD boards are the same.
What LCD are you using (URL please), and which library (URL please). Did the documentation for that LCD say which library to use. Did it give you test script to use?
How about a hint about what you mean by "does not work"
Unless they have changed their PC board those are the correct parameters for lcd.begin(). The sketch is also fairly standard except for the extra (and unneeded) lcd.setCursor step in setup().
Are you using an Arduino Yun or Due? If not then why are you using 'beta' software? If you are then did you check to see if the shield is compatible?
Did you see this on the Arduino download page? WARNING: The early Windows release 1.5.4 contained a bug that prevents it from working correctly on Windows 8. 1.5.4r2 fixes the issue.
Of course they didn't specify how the bug manifests itself.
Don
arduinodlb: What model is your LCD?
LCD Keypad Shield from DFRobot & Arduino Yún
[quote author=jack wp link=topic=191746.msg1417191#msg1417191 date=1381003504] There are many LCD libraries, and they are not all created equal. Also not all LCD boards are the same.
[/quote]
I followed the hint on DFRobot site and used the Lib included in the IDE 1.5.4 with changed pinning for the shield.
floresta:
Don
I use Arduino Yún and a W7 PC. Because I see only one block line in the LCD (playing with the contrast) there must be an initilization issue.
You are correct about the initialization issue.
Here is what is not wrong! - You are using a shield that plugs directly into your Arduino so the wiring should not be a problem. - You are using an established library that has worked for others with this shield and traditional Arduinos. - You are using the correct parameters with your LiquidCrystal lcd constructor.
A few possibilities come to mind: - The shield could be defective. - The shield could be incompatible with the Yún. - You could be having trouble downloading your code to the Yún.
How much experience do you have with your Yún? Have you been able to successfully download and run other programs that do not involve this shield?
Don
floresta:
Don
The shield works properly on Arduino 2009 with IDE 1.0.5. Incompatibility to Yun could be because I was not able until now to bring 5V DC to the 5V pin. Its always 3.3 V and I did not finde JP3 :-( Downloading the code works because I started with a blinking LED and thsi works.
Claus
Wow, good to hear that. If you had mentioned that earlier, It would have saved us lots of time.
Another bit of information you failed to share with us.
Great, you probably have solved the mystery.
[quote author=jack wp link=topic=191746.msg1418203#msg1418203 date=1381078300]
[/quote] But, how can I handle the voltage problem. In the documentation I can read that it is possible by JP3 to select 5V or 3.3 V for the shields. I did not found JP3 until now and have on 3V3 the same voltage as on 5V.
@Claus It would be a good idea for you to go back to your Arduino profile and enter your location.
One problem we are having is in interpreting what you are saying. Your English is very good but just not the same as what some of us are used to.
Here is an example relating to the phrase "until now" as used here: "I was not able until now to bring 5V DC to the 5V pin."
In American English this would be interpreted as: Up until this point in time I was not able to bring 5V DC to the 5V pin but now I can.
In other varieties of English (including yours I think) this means: At this point in time I am still not able to bring 5V DC to the 5V pin.
Please provide a link to that documentation
Don
floresta: @Claus It would be a good idea for you to go back to your Arduino profile and enter your location.
Don
@Don
Profile is changed. I understand the difference. I have only 3.3 V on the shield and no idea how to get 5 V there.
http://arduino.cc/en/Main/ArduinoBoardYun at Summary you will find:
AVR Arduino microcontroller Microcontroller ATmega32u4 Operating Voltage 5V Input Voltage 5V
and
http://arduino.cc/en/uploads/Main/arduino-Yun-schematic.pdf mentions "JP3(3.3V/5V) for Shield Application". But, I did not find JP3 in the schematics.
What power supply are you using to power your arduino? Is it USB, or what? You tested the voltage with a volt meter ?
[quote author=jack wp link=topic=191746.msg1418621#msg1418621 date=1381102193] What power supply are you using to power your arduino? Is it USB, or what? You tested the voltage with a volt meter ? [/quote]
USB 4.3 V on pin 5V (yesterday I had 3.3 V there, I do not know why this is changed) 3.3 V on pin 3V3
LCD does not work I will try an I2C sensor this evening
You have a problem with power, if you are reading 4.3 volts where the 5 volts should be. 1. Can you try a different USB power source, and/or cable ? 2. Do you have other loads on the arduino that may be drawing down on the 5V line? 3. If you plug in your other arduino board to that USB, what voltage does it read?
I use a 5 V DC power supply connected to VIN now and got stable conditions on the shield.
The LCD Keypad shield does not work again.
Therefore I was going one step back and used a RTC DS1307 on Aduino 2009 & IDE V1.0.5. This works properly.
The files you can download from Arduino Quelltexte - Browse /IDE_V1.0.5_and_higher at SourceForge.net.
The same shield connected to Arduino Yún with the same RTClib gave me the error “RTC_DS1307 does not name a type”.
This is not clear for me. Do you have any idea where the differences are? Di you need further information?
Claus
I am having a hard time keeping up. First there was a LCD problem with IDE 1.5.4 Then the LCD works on another arduino board. Then your arduino had only 3.3 volts on the 5 volt pin. Now you get Compile errors when you use a RTC shield.
Lets slow down. The last thing I mentioned was that you had a problem with your power supply ( 5v). Have you got that fixed yet. You replied
. I don't really know what that means. Do you read 5.1 Volts on the 5volt pin now?
I don not have a Yun. Is this diagram correct for the Yun (eg, D7 is now handshake)? http://forum.arduino.cc/index.php/topic,189755.0.html There is no D7 or D8 etc. anymore?
