Liquid flow rate sensor
i need connect a yf-s403 to an arduino one, i need help please
Use wire.
It is an Arduino Uno not a one, even though Uno is Itialian for one, you don't translate that bit.
Please post a link to your sensor using the chain icon then people with mobile devices can use it.
One datasheet states that the sensor has three wires. Ground (black), +5volt (red), and digital out (yellow). Digital levels (0.5v/4.5v) from a hall IC. Not clear how many pulses/liter. Leo..
Check this nearby conversation. I don't think you need to use wire, I'm pretty sure nobody else does.
http://forum.arduino.cc/index.php?topic=325842.msg2250876#msg2250876.
The pulse per litre is often on the device, or the supplier should advertise it. You can calibrate it by simply changing the conversion factor. I imagine you could test it with a known quantity.
Nick_Pyner:
Check this nearby conversation. I don’t think you need to use wire, I’m pretty sure nobody else does.
Wire - as in metal conducting material usually covered in an insulated material.
