LiquidCrystal change custom char
Hi, I want to change a custom char, mid-way through a sketch. And the reason that I don't just use another char, is that I have to use all 8 chars, and I need them to change to a lot more than 8 states.
So far, I have made this:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte customChar[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b10101,
  0b00000
  lcd.createChar(0, customChar);
  lcd.begin(16, 2);
  lcd.write((uint8_t)0);
  customChar[8] = {
    0b00000,
    0b00000,
    0b00000,
    0b00000,
    0b00100,
    0b00000,
    0b10100,
    0b00000
  delay(3000);
But I get error:
C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_362623\sketch_jun26a.ino: In function 'void loop()':
sketch_jun26a:32:3: error: cannot convert '<brace-enclosed initializer list>' to 'byte {aka unsigned char}' in assignment
exit status 1
I don't know how to fix this.
  customChar[8] =
    0b00000,
    0b00000,
    0b00000,
    0b00000,
    0b00100,
    0b00000,
    0b10100,
    0b00000
You cannot define all 8 elements of an array like this in a function, only when it is first declared
The easiest way to do what you want is to declare and define 2 arrays, each with the custom character definition and copy the required one to a third array that you use in the function
Something like this (untested)
byte customChar_1[8] =
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b10101,
  0b00000
byte customChar_2[8] =
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00100,
  0b00000,
  0b10100,
  0b00000
byte activeCustomChar[8];
  memcpy(activeCustomChar, customChar_1, 8);
  lcd.createChar(0, activeCustomChar);
  lcd.begin(16, 2);
  delay(3000);
Note that if a custom character is currently displayed on screen then changing its definition will change what is displayed even if it was previously printed with the previous definition
At this point, you have an array called "customChar", but it has only eight elements, so to assign anything to the ninth element is clearly A Bad Thing.
Just create a new array, and call createChar with it as a parameter.
To change the glyph (image) of Custom Character 0 you will have to call "lcd.createChar(0, newGlyph);" again.
byte Glyph0A[8] =
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b10101,
  0b00000
byte Glyph0B[8] =
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00100,
  0b00000,
  0b10100,
  0b00000
  lcd.begin(16, 2);
  lcd.createChar(0, Glyph0A);
  delay(3000);
  lcd.createChar(0, Glyph0B);
  delay(3000);
If you replace a custom character in mid sketch, the new character will replace all instances of the original character when the display is updated.
