I am using this Liquidcrystal for SPI library:
http://playground.arduino.cc/Main/LiquidCrystal
I'm using the latest Arduino IDE 1.6.7 and compiling the "Helloworld_SPI" example for the Zero board, I get some errors due to the "old" spisettings setup:
error: invalid conversion from 'uint8_t {aka unsigned char}' to 'BitOrder' [-fpermissive]
SPI.setBitOrder(_bitOrder);
Changing the following code:
//set clockDivider to SPI_CLOCK_DIV2 by default which is 8MHz
_clockDivider = SPI_CLOCK_DIV2;
SPI.setClockDivider(_clockDivider);
//set data mode to SPI_MODE0 by default
_dataMode = SPI_MODE0;
SPI.setDataMode(_dataMode);
//set bitOrder to MSBFIRST by default
_bitOrder = MSBFIRST;
for the new way for the spisettings:
SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0));
The sketch now compiles without errors
BUT now when I program the Zero board with this sketch, the microcontroller does not run :o
trying to figure-out what is happening, I include some "serial.print" lines into the sketch for getting some feedback/debugging through the serial monitor but no debugging messages apear... nothing.... (even the setup part of the sketch), gets running. :o
Executing exactly the same sketch in a Leonardo board everything works perfectly but in the Zero board... nothing works.
¿any idea on what is wrong?
Thanks
