Does anyone know if the LiquidCrystal.h library is working with a 8*2 display?
I use the EONE high cost-effective 8*2 Characters LCD display but i can't seem to get it to do anything.
Thanks alot!
Thanks alot!
That display should work with the LiquidCrystal library.
Post a photograph of your connections and a copy of your sketch and we will try to help.
Don
Project: LCD til test
Hardware: LCD 8x2
Filename: LCD_test_8x2_standard.pde
Rev. nr.: 001
Author : Hans Erik Tjelum
Company: www.let-elektronik.dk
Date: 2011-03-31
Copyright: Copyleft
Detaljeret beskrivelse:
LCD-program til at teste et LCD
The circuit:
LCD pins:
1: GND - digital common
2: +5V - digital supply
3: Vo - LCD contrast input*
4: RS - Register Select -> Arduino pin 12
5: Enable - Active low -> GND
6: R/W - Read/Write 1=Read -> Arduino pin 11
7: D0 - Not used
8: D1 - Not used
9: D2 - Not used
10: D3 - Not used
11: D4 - Used for 4-bit mode -> Arduino pin 5
12: D5 - Used for 4-bit mode -> Arduino pin 4
13: D6 - Used for 4-bit mode -> Arduino pin 3
14: D7 - Used for 4-bit mode -> Arduino pin 2
15: LED Anode -> Arduino pin 9 (PWM)
16: LED Cathode -> GND
* 10K trimmer resistor:
ends to +5V and ground, wiper to LCD Vo
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(8, 2);
// Print a message to the LCD.
lcd.print(" LE 2011");
pinMode(9, OUTPUT);
analogWrite(9, 128);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
analogWrite(9, 64);
analogWrite(9, 255);
Thanks alot!
Post a photograph of your connections ...
We have to be able to follow each wire and determine exactly where it is connected. We also have to be able to see what is being displayed.
Are you able to see a single row of blocks on the top line of your display with only pins 1, 2, 3, 15, and 16 connected?
Don
