But the display only shows dark rectangles in the first line (all 5x8 Dots are enabled). I think i've wired it correctly.
Does anyone know what i'm doing wrong?
I'm using 4-bit mode. This is what my wiring looks like:
LCD RS -> Arduino digital Pin 5
LCD R/W -> Arduino digital Pin 6
LCD E -> Arduino digital Pin 1
LCD D4 -> Arduino digital Pin 8
LCD D5 -> Arduino digital Pin 9
LCD D6 -> Arduino digital Pin 10
LCD D7 -> Arduino digital Pin 12
LCD V SS -> Arduino GND
LCD V DD -> Arduino 5 V
LCD V L -> Arduino GND
LCD A -> Arduino 3.3 V
LCD K -> Arduino GND
no, i've connected it to ground. I've have connected an 100 ohm resistor between LCD V L and GND during tests. The contrast was lower. Is it bad, to just connect it to gnd?
I don't think connecting it to ground is a good idea. Vee (usually pin 3) needs a voltage between 0 and 5v, by connecting it to ground the contrast is at the end of the scale. You'd either get just black rectangles or a blank display. Use a 20k potmeter and connect it like this:
You are using pin 1 for the enable-signal. Pin 1 is Rx on the serial/USB-port, so you may need to disconnect the serial/USB-cable to to prevent interference. I suggest you avoid using pin 0 and 1 if you have another free pin available.
thx! It seemed there were two problems. Now all works fine! First problem, i resolded the LCD cable. I think there was a "cold" solding. And i switched from using pin 1.
