LiquidCrystal on ESP32-S3
I've issues to run LiquidCrystal on BPI-Leaf-S3.
I read this and this issues. Still I cannot understand how to fix the problem.
Sample code:
// main.cpp
#include <LiquidCrystal.h>
#include "foo.h"
Foo foo;
  Serial.setDebugOutput(true);
  foo.Begin();
// foo.h
class Foo
public:
    Foo();
    void Begin();
private:
    LiquidCrystal *_lcd;
// foo.cpp
#define PIN_LCD_RS  3
#define PIN_LCD_EN  13
#define PIN_LCD_D4  4
#define PIN_LCD_D5  30
#define PIN_LCD_D6  12
#define PIN_LCD_D7  6
void Foo::Begin()
    Serial.println("before");
    _lcd = new LiquidCrystal(PIN_LCD_RS, PIN_LCD_EN, PIN_LCD_D4, PIN_LCD_D5, PIN_LCD_D6, PIN_LCD_D7);
    Serial.println("after");
Since I init the LCD class in Begin function and NOT in the constructor it should not hang the ESP as stated in the issues above. Still my output is:
Reconnecting to /dev/ttyACM0 . Connected!
before
Disconnected (device reports readiness to read but returned no data (device disconnected or multiple access on port?))
before
before
before
I also added build_flags = -DCORE_DEBUG_LEVEL=5 in platfomio.ini but I don't see any crash log in the serial output.
What is the right way to use this library for ESP32-S3?
You don't use Arduinos way to setup the hardware. That is just calling for trouble.
Sorry, what is the "Arduinos way to setup the hardware"?
Oops, forget what I wrote: I just saw that you use GPIO6, which is used by SPI Flash - which will most likely the cause of your problem
