Hi
I had problems with my LCD using this function to initialize:
LiquidCrystal(rs,enable, d0, d1, d2, d3)
I used this to save one pin, the rw, that was conected to GND.
In the source code I found this at line 50:
init(1, rs, -1, enable, d0, d1, d2, d3, 0, 0, 0, 0);
and this along the source code:
if (_rw_pin != -1) {
yap,yap,yap,......
I think that putting -1 into an unsigned value could be a problem (_rw_pin is uint_8), because then it's compared with -1 and I think the comparision it's made converting the unsigned value to an integer with sign and then compare 255 with -1 under an integer context.
i make a test, changin the library adding NOT_RW constant to .h with this value:
define NOT_RW (uint8_t)-1
And using this "special -1" (maybe 255), everything works well. using 255 as an special value it's not a problem. Nobody have 255 inputs/outpus in Arduino. I think ;)
The new library has this fixed? I get my library from the arduino website 2 days ago, and i think that it's the newer version.
Saludos!
