I'm using a 328. The code above is just a test. In my actual code I never even get a response from Twitter, like my message is not submitted. I get as far as it saying Tweet Sent. I'll try deleting some of the variables like you suggested.
* A simple sketch that uses WiServer to send a tweet with the current system time every 5 minutes
#include <WiServer.h>
#include <LiquidCrystal.h>
#define WIRELESS_MODE_INFRA 1
#define WIRELESS_MODE_ADHOC 2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,2}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"Robot"}; // max 32 bytes
//LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
LiquidCrystal lcd(4, 3, 8, 7, 6, 5);
unsigned char security_type = 0; // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
char temp_val[3];
char temps[3] ="";
char* weather = "unknown";
int inPin = 5; // select the input pin for analog temp value
int inPin2 = 4;
int inVal;
int inVal2;// integer value for input read from sensor
int i;
int samples[8];
int sensmPin = 1;
int t=0;
int ti=0;
int pt=0;
char n[6] = " ";
int x=0;
char* place=" ";
int photocellPin = 3; // the cell and 10K pulldown are connected to a0 also try 1k for brighter areas
int photocellReading; // the analog reading from the analog resistor divider
int inVal3=0;
int samples2[8];
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"12345678"}; // max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, // Key 0
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 1
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 2
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters
// Auth string for the Twitter account
char* auth = "[bWlsbGVyc2hvbWU6c3Bpa2VzMzM=]"; // Base64 encoded USERNAME:PASSWORD
// This function generates a message with the current system time
void currentTime() {
WiServer.print("Out temp is ");
Serial.println("Out temp is ");
WiServer.print(ti);
Serial.println(ti);
WiServer.println(".");
Serial.println(".");
WiServer.print("Inside temp is ");
Serial.println("Inside temp is ");
WiServer.print(t);
Serial.println(t);
WiServer.print("Weather is ");
Serial.println("Weather is ");
WiServer.print(weather);
Serial.println(weather);
WiServer.print("Robo Temp has been on for ");
Serial.println("Robo Temp has been on for ");
WiServer.printTime(millis());
// A request that sends a Tweet using the currentTime function
TWEETrequest sentMyTweet(auth, currentTime);
lcd.begin(16,2);
lcd.print("Robo Temp 3000");
// Initialize WiServer (we'll pass NULL for the page serving function since we don't need to serve web pages)
//WiServer.init(sendMyPage);
WiServer.init(NULL);
// Enable Serial output and ask WiServer to generate log messages (optional)
Serial.begin(57600);
WiServer.enableVerboseMode(true);
// Time (in millis) when the next tweet should be sent
long tweetTime = 0;
//void enableVerboseMode(boolean enable);
void TempWrit()
lcd.setCursor(0, 0);
lcd.clear();
lcd.print(place);
lcd.print(" temp ");
lcd.print(x);
lcd.print((char)223);
lcd.print(" F.");
lcd.setCursor(0,1);
lcd.print(weather);
lcd.setCursor(16,1);
lcd.autoscroll();
for (int thisChar = 0; thisChar < 16; thisChar++) {
lcd.print(" ");
delay(400);
lcd.clear();
lcd.noAutoscroll();
void WeatherOut()
for(i = 0;i<=7;i++) // gets 8 samples of temperature
samples[i]= ( 5.0 * analogRead(inPin) * 100.0) / 1024.0;
inVal = inVal + samples[i];
inVal = inVal/8.0; // better precision
t = ((inVal * 9)/ 5 + 32);
inVal = 0; //reset variable
x=t;
itoa(t,temp_val,10);
place="Out";
void WeatherIn()
samples[i]= ( 5.0 * analogRead(inPin2) * 100.0) / 1024.0;
inVal2 = inVal2 + samples[i];
inVal2 = inVal2/8.0; // better precision
ti = ((inVal2 * 9)/ 5 + 32);
inVal2 = 0; //reset variable
x=ti;
itoa(ti,temp_val,10);
place="In";
void StatusGet() {
photocellReading = analogRead(photocellPin);
samples2[i]= ( analogRead(photocellPin));
inVal3 = inVal3 + samples2[i];
inVal3 = inVal3/8.0; // better precision with 8 samples
if (inVal3 < 50) {
weather = "Night Time";
} else if (inVal3 < 300) {
weather = "Cloudy";
} else if (inVal3 < 650) {
weather = "Partly Cloudy";
} else if (inVal3 < 850) {
weather = "Partly Sunny";
weather = "Sunny";
WeatherOut();
StatusGet();
TempWrit();
WeatherIn();
weather=" ";
TempWrit();
// Check if it's time to sent a tweet
if (millis() >= tweetTime) {
Serial.println("Sending Tweet ");
sentMyTweet.submit();
Serial.println("Tweet Sent");
// Send next tweet 1/2 hr from now
tweetTime = tweetTime + 300000;
// Run WiServer
// WiServer.server_task();
// delay(10);
