LiquidCrystal's setCursor bugs
With Arduino 0017 version of LiquidCrystal, when I do lcd.setCursor(0,0); it in fact does lcd.setCursor(8,0). setCursor(1,0) does setCursor(9,0) and so on. I'm using an 16x2 chr lcd.
Function void LiquidCrystal::setCursor(int col, int row) in the old version has been changed to void LiquidCrystal::setCursor(uint8_t col, uint8_t row).
When I also change the first row, the pick-up-table int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 }; type from int to uint8_t, the function starts to work as expected.
But why? Obviosly it should work either way. Is this a GCC bug?
Did you remember to put lcd.begin(16,2); in your setup?
Yes. begin(16, 2); doesn't help.
Just try:-
lcd.begin(2,16);
No, the function is defined as:
void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS);
so begin(16,2) is the correct form.
If the table row_offsets[] is defined as ints, code bugs at this line:
command(LCD_SETDDRAMADDR | (col + row_offsets[row]));
Of course it shouldn't matter if you add either an int or uint8_t to an uint8_t. Int uses slightly more memory, but the result should be the same. So this is a compiler bug?
Additional info:
  • I'm using a Mac, if this affects anything here.
  • If I remember correctly, the 0017 version worked fine in some version of my "sketch". So when I change something elsewhere in the application, this setCursor() behavior changes even it should not.
I also use lcd.begin(16,2); and it works spot on.
