Lire une zone de texte ethernet shield
salut,
j'aimerais bien lire ce qui est écrit dans une zone de texte d'une page web afin d'afficher ce texte avec animations (scroll) voilà mon code j'ai réussi à afficher quelques formes prédéfinis est ce quelqu'un peut m'aider pour faire animer un texte ecrit dans la zone de texte dans ce serveur web
merci d'avance
MONPFE3.ino (6.35 KB)
#include <SPI.h>
#include <Ethernet.h>
#include "LedControl.h"
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 177);
LedControl lc=LedControl(7,6,5,1);
/* we always wait a bit between updates of the display */
unsigned long delaytime=100;
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
String readString;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
} // open up serial port connection to PC
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
The MAX72XX is in power-saving mode on startup,
we have to do a wakeup call
lc.shutdown(0,false);
Set the brightness to a medium values /
lc.setIntensity(0,8);
and clear the display */
lc.clearDisplay(0);
void writeArduinoOnMatrix() {
/* here is the data for the characters */
byte a[8]={B00000000,B00100000,B01100000,B11111111,B11111111,B01100000,B00100000,B00000000};
/* now display them one by one with a small delay /
lc.setRow(0,0,a[0]);
lc.setRow(0,1,a[1]);
lc.setRow(0,2,a[2]);
lc.setRow(0,3,a[3]);
lc.setRow(0,4,a[4]);
lc.setRow(0,5,a[5]);
lc.setRow(0,6,a[6]);
lc.setRow(0,7,a[7]);
lc.setRow(0,9,a[8]);
void writeArduinoOnMatrix5() {
byte a[8]={B11111111,B11000011,B10100101,B10011001,B10011001,B10100101,B11000011,B11111111};
void writeArduinoOnMatrix2() {
byte a[8]={B00000000,B00000100,B00000110,B11111111,B11111111,B00000110,B00000100,B00000000};
void writeArduinoOnMatrix3() {
byte a[8]={B00011000,B00111100,B01111110,B00011000,B00011000,B00011000,B00011000,B00011000};
void writeArduinoOnMatrix4() {
byte a[8]={B00011000,B00011000,B00011000,B00011000,B00011000,B01111110,B00111100,B00011000};
/* now display them one by one with a small delay */
// Create a client connection
if (client) {
boolean currentLineIsBlank = true;
String buffer = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.print(c);
buffer+=c;
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n' ) {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("");
client.println("");
client.println("");
client.println("");
client.println("");
client.println("MATRICE DE LED");
client.println("");
client.println("");
client.println("
MATRICE DE LED
client.println("
client.println("
client.println("
Choose your form
client.println("
client.println("<a href="/?haut"">Fleche haut");
client.println("<a href="/?bas"">Fleche bas
client.println("
client.println("
client.println("<a href="/?gauche"">Fleche gauche");
client.println("<a href="/?droite"">Fleche droite
client.println("
client.println("
client.print("<FORM action="http://192.168.1.177/\" >");
client.print("
<input type="text" name="text" id="ST" value=""/>" );
client.println("
client.println("
client.print("
<INPUT type="submit" value="Submit"> ");
client.println("
client.println("");
client.println("");
delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?haut") >0)
writeArduinoOnMatrix() ;
if (readString.indexOf("?bas") >0)
writeArduinoOnMatrix2() ;
if (readString.indexOf("?gauche") >0)
writeArduinoOnMatrix3() ;
if (readString.indexOf("?droite") >0)
writeArduinoOnMatrix4() ;
if (readString.indexOf("?text") >0)
writeArduinoOnMatrix5() ;
readString="";
salut
j'utilise un formulaire avec la methode GET pour lire les champs de saisie texte :
et je récupère le texte comme tu le fais déjà avec
if (readString.indexOf("?texte=") >0) .... sachant que le texte saisi suit le signe =
merci beaucoup pour votre attention
mais if (readString.indexOf("?texte=") >0) ne me permet pas de récupérer ce qui est écrit dans la zone de texte ! en faite j'ai besoin de récupérer une chaîne de caracactére contenant le message déjà écrit pour l'afficher sur une matrice de LED! le problème c'est que j'arrive pas à récupérer le message écrit dans la zone de texte
