LIS3DH accelerometer sampling frequency
Hello,
I am working on a project where I need to determine the vibration frequency of a small coin vibration motor (VPM2 Solar Robotics). The data sheet mentions it vibrates between 150 - 250 Hz. I figure this variation depends on the voltage given to the motor so I am attempting to confirm this using an LIS3DH accelerometer (Adafruit Industries). If it turns out the frequency of the motor does not vary with voltage, I would still like to figure out how to set up the accelerometer to give the sampling frequency I want.
The datasheet for the LIS3DH mentions it can work between 1 Hz and 5 kHz. However, when I take a 5 second sampling from the motor while it is running (being given the maximum voltage of 3.4 volts according to its datasheet) I am getting around 3500 samples. To my understanding, this means that only about 700 samples are being taken every second.
Here is the code I am using:
//Reading from the accelerometer
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
//accelerometer
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
#define LIS3DH_CS 10
//timing
#define INTERVAL 200
//motor
const int VoltCont = 3;
Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
//ExponentialFilter <float> Filtered(80,0);
  //wait until the console is opened
  Serial.begin(1000000);
  while (!Serial) delay(10);
  if (! lis.begin(0x18)) {
    //Serial.println("Couldn't start");
    while (1) yield();
  //Serial.println("LIS3DH found!");
  lis.setDataRate(LIS3DH_DATARATE_LOWPOWER_5KHZ);
  pinMode(VoltCont, OUTPUT);
  // take 'times' number of readings
  for (int times = 1; times <= 1; times++){
    delay(5000);
    analogWrite(VoltCont, 174);
    unsigned long starttime = millis();
    unsigned long endtime = starttime;
    delay(100);
    //Run the motor for 5 seconds, sampling using the accelerometer
    while((endtime - starttime) <= 5000){
      static unsigned long lastRead;
      if (micros() - lastRead >= INTERVAL){
        lastRead += INTERVAL;
        sensors_event_t event;
        lis.getEvent(&event);
        Serial.print(event.acceleration.z);
      endtime = millis();
   analogWrite(VoltCont, 0);
   delay(20000);
void loop(){
I am using an ATmega2560, which I read according to this thread can handle the baud rate I set it to. I use PuTTy as the serial monitor to export the data to a .txt file where I comb through the signal in MatLab.
I found here that the LIS3DH library may not actually set the data rate to 5kHz with the method I used. However, this is a programming issue that is a little beyond me, as I don’t quite know where to begin troubleshooting this. I’m also curious if maybe the limitation might be with something else, like the arudino or the serial monitor?
Another thing I am wondering is if it’s even necessary to have such a high sampling frequency. Would the 700 Hz work just fine to determine the frequency the motor runs at, assuming its max frequency really is 250 Hz?
