lis3lv02dq over I2C
Hey
Currently trying to connect using I2C to this accelerometer (the lis3lv02dq). I have been having problems getting the send and return to work, so I simplified my code down until I could get it working. Afterwards, I'd concentrate on getting the details from it.
My wiring is:
  • 3.3v to VDD
  • analog 4 to SDA
  • analog 5 to SCL
  • digital 9 to CS
Right now, I'm just asking it for its physical address, which the datasheet said ought to be 3A. Currently it just returns ááá, if I serial.println as a DEC or HEX.
Here's the code:
#include <Wire.h>
#define i2cLIS 0x1D
void setup ()
pinMode(9, OUTPUT);
digitalWrite(9, HIGH);
Wire.begin(); // join i2c bus (address optional for master)
Wire.beginTransmission(i2cLIS);
Wire.send(0x21); // CTRL_REG1 (20h)
Wire.send(0x87); // Device on, 40hz, normal mode, all axis's enabled
Wire.endTransmission();
byte whoI;
Wire.send(0x0F);
Wire.requestFrom(i2cLIS, 1);
if(Wire.available())
whoI = Wire.receive();
Serial.println(whoI, DEC);
Any thoughts on what might be the problem?
Okay, have done some debugging steps.
When I attempt to print from within if(Wire.available()){ }, it does not show up.
IN so far as I can tell there is a problem with this section of my code, or anything before it required to ID the data required, and request it.
Currently, the below Code does not print '1':
byte whoI;
Wire.send(0x0F);
// whoI = Wire.receive();
Serial.println(1);
I decided that hooking it up to SPI would be a good alternative, so I used the code given on http://www.nearfuturelaboratory.com/2006/09/22/arduino-and-the-lis3lv02dq-triple-axis-accelerometer/.
It doesn't read, but returns a 'who am i' code of [0].
I know I'm really asking a lot out of ignorance (this is my first non-pentometer/photoresistor/simple things project), but what debugging steps would you recommend going through to get to the bottom of this?
:smiley: Pay no heed, I think I've just found a loose connection. Gosh durn it!
Hey
My wiring is:
  • 3.3v to VDD
  • analog 4 to SDA
  • analog 5 to SCL
  • digital 9 to CS
Here's the code:
Quote:
#include <Wire.h>
#define i2cLIS 0x1D
void setup ()
pinMode(9, OUTPUT);
byte whoI;
Wire.send(0x0F);
Icilian,
The line of code..."Wire.send(0x21); // CTRL_REG1 (20h)"......
You use 0x21 for your address parameter, but in your comment you state control register address "CTRL_REG1(20h).
This is a problem, because the code is actually addressing the CTRL_REG2 register, and then you plug 87h into that address and you are NOT activating anything, you are setting your Full Scale to +-6g, enabling Data_Ready generation, setting the SPI interface to 3-wire, and setting the Data Alignment Selection to 16-bit left justified.
Try using, "Wire.send(0x20); // CTRL_REG1 (20h)", instead.
Cheers! :slight_smile:
Argh! What a clutz I am!
:smiley: thanks a lot Jshwaa!
Not a problem. :slight_smile: Did it work now?
Aha, I should have said that! Yes, it did.
After I discovered it had some loose connections, I soldered in legs, and it worked fine. Then I saved the version of the sketch with the mistake your caught in it, and it broke all over again.
Thanks to you, I still have most of my hair left! That was driving me crazy.
