list of 10 random numbers
I'm working on a bunch of sorting algorithems. I need to sort an array of x numbers.
Unfortunately I stumbled acros a problem.
If I make an random array of numbers below 10. There are some large numbers passed in that i didn't declare.
This is my code:
int quantity = 10;
list[]={};
void randomarray(quantity)
for (int i=0; i< quantity; i++)
int randint = random(0,quantity);
list = randint;
    If I print the array i get something like this:
    3
    1
    261
    2
    514
    8
    777
    5
    0
    8
    Where in earths name do these large numbers come from?
    I can't figure it out! :fearful:
Welcome!
Try to use
 list[i] = randint;
instead of
 list = randint;
and also use code button for source code to be better readable.
EDIT: You've printed a random memory regions since list = randint; command changed a pointer to array not a value inside of array.
Thank you very much!
What a great site is this.
That's what I have, I accidently forgot that part when I was translating it from dutch.
I'm sorry!
Do you have any idea how the large numbers are passed in with this code?
and
Can I give you credit for your help? :stuck_out_tongue:
Budvar10:
Welcome!
Try to use
 list[i] = randint;
instead of
 list = randint;
In fact it's the lack of code tags that took out the i index in square brackets and turned on italics instead.
Wow! You guys helped me out too! I am working on a similar project where I am printing random numbers on 16X2 LCD using this tutorial. Thanks! :slight_smile: :smiley:
This will not give you random numbers. Only Psuedo-Random numbers.
UnderGround_Hacker:
You need truly random numbers to test your sorting algorithms? The question was not about random numbers; it was about sorting algorithms.
I prefer pseudo-random as then the sort has exactly the same work to do each time I test.
@JimboZA
Thank you sir. :-[
@Guido83
I do not deserve. Give it to Delta_G for the post above.
@ Delta_G
Thank You,
This is what i needed to know!
It works perfectly now! :smiley:
