I've seen in a few places on line where people have recorded their 433 MHz receivers using audacity. I have not found a place that really describes how this should be wired.
How exactly should this be wired on a breadboard? Specifically, where do I take the output from the reciever? Do I need any resistors? I appreciate the help.
Audio inputs on PCs are not designed for 5V input and may even be damaged by it. You will get better results if you use a 5:1 or higher resistive voltage divider, like the attached.
