Greetings Friends, and Thank You in advance For Your Help.
(FYI, Noobs call me a Nube) I'm inexperienced with 3D printing, and highly trained in nothing. I tried to include any pertinent info (specs, settings, screenshots, code, tears).
My issue is a lit-but-blank screen after flashing Firmware. I got a "verified" upload from Arduino, then the blank screen on the printer, which is an Ender 3 with a Creality v1.1.4. The end of the upload progress report was this:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.*
avrdude: erasing chip
avrdude: Using SCK period of 10 usec
avrdude: reading input file "C:\Users\User\AppData\Local\Temp\arduino_build_855399/bEnder-ISP-try-082121-FlashUpload-VERIFIED.ino.hex"
avrdude: writing flash (4576 bytes):
Writing | ################################################## | 100% 6.44s
avrdude: 4576 bytes of flash written
avrdude: verifying flash memory against C:\Users\User\AppData\Local\Temp\arduino_build_855399/bEnder-ISP-try-082121-FlashUpload-VERIFIED.ino.hex:
avrdude: load data flash data from input file C:\Users\User\AppData\Local\Temp\arduino_build_855399/bEnder-ISP-try-082121-FlashUpload-VERIFIED.ino.hex:
avrdude: input file C:\Users\User\AppData\Local\Temp\arduino_build_855399/bEnder-ISP-try-082121-FlashUpload-VERIFIED.ino.hex contains 4576 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 4.36s
avrdude: verifying ...
avrdude: 4576 bytes of flash verified
Summary
This text will be hidden
avrdude done. Thank you.
I've seen a lot online about some relation to the bootloader, and also conflicting info, and i've tried both with no success.
I've attached some screenshots of the Arduino settings.
Also, "Get Board Info" yields "Native serial port, cannot obtain info," and "Burn Bootloader" yields "Error while burning bootloader."
Summary
Thanks again. -kev
