Literally Boil water with Arduino
I am kind of a noob to Arduino projects but have bedazzled with Arduino projects and am well aware of what it is capable of. Right now I am in the middle of a side project. One component to my projects is to literally boil water with some part of the Arduino. My only problem is how am I suppose to heat it up or what part am I suppose to buy to heat this up. A waterproof component would be preferable. Thanks!!
Arduino can control AC power to a hot water pot.
http://www.walmart.com/search/?query=hot%20water%20pot&typeahead=water%20pot
If you connect the power supply backwards or to a port pin, you might be able to boil a drop of water on some part of an Arduino.
monitor temp with sensor and control heating element with relay, easy as pie
jremington:
But only once. :slight_smile:
Henry_Best:
original spec did not define if this was a single or multiple batch process.
you can take apart an old coffee pot
http://www.cofei.com/articles/inside-a-coffee-maker.html
then connect a relay to the heater element and use that to boil water.
or
google 231319587269
you can get these in 120 Volt or 240volt
these too can be controlled with a relay
