Lithium cells / batteries. More efficient to step-up or step-down
Hey guys,
I'm building a battery powered LED project.
I need a maximum of 1A @ 5v. Current draw will typically be less.
I want to use "14500" lithium cells.
I plan to use a separate regulator board (to meet my current demands) and bypass the onboard regulator of the arduino.
Size/weight are issues. Through-hole components preferred for ease of prototyping.
1. Is it more efficient to step up a single 3.7v cell or step down two cells in series (7.4v)?
2. Will I run into issues using 14500 cells in parallel to increase my capacity?
3. Will I run into issues using 14500 cells in series? (They have onboard protection circuits)
Possible equipment options:
Batteries: (upto 2C discharge rate) Recommendations For You - DealeXtreme
Voltage Regulator:
Both: http://dx.com/p/mini-dc-dc-voltage-stabilizer-regulator-module-red-126106
Step up (TDFN package): Mixed-signal and digital signal processing ICs | Analog Devices
Step up (SOT23 package): Mixed-signal and digital signal processing ICs | Analog Devices
My gut reaction is that having a single cell is going to simplify things(*) even if it doesn't
bring any efficiency improvement - at the expense of less endurance.
(*) no charge balancing needed, fewer mechanical connections, simpler to monitor
one cell.
MarkT:
one cell.
Cells are being charged in a balanced charger anyways. None of your other points are concerns of mine. Mostly looking at efficiency here to prolong usable battery life.
For what it's worth, here is my opinion.
A switching regulator in a step down configuration is usually 80-90% efficient in most cases. You will not get that kind of efficiency from a step up or boost scenario. In simplest terms, if you boost the voltage, you get lower instantaneous current.
Panici:
Yes.
Panici:
You can discharge them in series but you can't charge them that way.
Take a look at this boost regulator from Pololu. The efficiency is over 80% at up to 700 mA output, with 3.3 V input. The efficiency will be a bit lower as the voltage drops below that, but the typical behavior is well documented on this page http://www.pololu.com/product/2115
If you google "switching regulator efficiency", you will find lots written about this subject, for example http://cds.linear.com/docs/en/application-note/an46.pdf.
What sort of LEDs will you be using, and how many of them? if you are planning to run the LEDs from the 5V supply with a series resistor, then that is a simple but inefficient solution. A more efficient solution would be to run the entire system from 3.7V. However, if your LEDs have about 3V forward voltage, then you may need to use constant-current drivers with them to avoid too much loss of brightness as the battery discharges.
More sophisticated boost regulators can get >95% efficiency, it just depends how many
discrete MOSFETs you are prepared to use, though I suspect there are some one-chip
boost regulators now that use synchronous switching rather than a schottky diode
(a major source of loss for low voltage converters).
The awesome LT3791 claims 98.5% boost or buck efficiency at 100W, but needs 4
external MOSFETs and lots of other components, this would be overkill for a small
DC-DC converter, but the principles are sound - live in hope of finding a one-chip
solution like this for all low power buck/boost needs!
One other factor is the same one that makes transmission lines run at very high voltages. Stepping down will draw lower current from the battery and incur less I-squared-R loss.
