Lithium monitor
Hello
i am new to arduino and one of my first projects is the lithium battery monitor.
I have a basic knowledge on lcd and inputs and outputs but i searched the web with no results.
I would like to make a monitor that would just measure the voltage on A0 and VIN and display everything on a 16X2 LCD via I2C.
Can any one help me with the connections and the code because i have tried almost everything i know with no real results.
I just need the LCD to display the Voltage and the percentage and maybe a little battery indicator.
Thank you
So post that as a starting point.
Tell us what you expected it to do, and what it actually did.
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
lcd.begin(16, 2);
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (4.2 / 1023.0);
// print out the value you read:
Serial.println(voltage);
lcd.setCursor(0, 0);
lcd.print(“Voltage is:”);
lcd.print(voltage);
lcd.print(“V”);
delay(1500);
Now, when you've added the [code][/code] tags, how about you tell us the
bit ?
I connected the lcd and the probes to gnd and A0.
I want to measure the voltage of a 18650 cell with it.
The display must display for example:
Voltage is: 4.15V
:IIIII|
Voltage is: 3.9V
:IIII |
Voltage is: 3.7V
:III |
Voltage is: 3.5V
:II |
Voltage is: 3.3V
:I |
Voltage is: 3.1V
Ok some progress but if i go under 3.8V the displaz still shows only 75%
ReadAnalogVoltage
lcd.begin(16, 2);
float voltage = sensorValue * (4.82 / 1023.0);
if (voltage > 4.0 ){
lcd.print(“100%”);
else if (voltage > 3.8 || voltage < 4.0 ){
lcd.print(“75%”);
else if (voltage > 3.6 || voltage < 3.8 ){
lcd.print(“50%”);
else if (voltage > 3.4 || voltage < 3.6 ){
lcd.print(“25%”);
else if (voltage > 3.4 || voltage < 3.0 ){
lcd.print(“0-25%”);
delay(1500);
lcd.clear();
Don’t you mean else if (voltage > 3.8 && voltage < 4.0 ){
I finally did it if some one wants to use the code they can do so
  ReadAnalogVoltage
//konec
byte newChar1[8] = {
  B11111,
  B00001,
  B11101,
  B11101,
  B11101,
  B11101,
  B00001,
  B11111
//Vmes
byte newChar2[8] = {
  B11111,
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
  B11111
//yacetek
byte newChar3[8] = {
  B01111,
  B01000,
  B01011,
  B11011,
  B11011,
  B01011,
  B01000,
  B01111
//PRAZEN
byte newChar4[8] = {
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111
//Prazna kapica
byte newChar5[8] = {
  B01111,
  B01000,
  B01000,
  B11000,
  B11000,
  B01000,
  B01000,
  B01111
//Prazen konec
byte newChar6[8] = {
  B11111,
  B00001,
  B00001,
  B00001,
  B00001,
  B00001,
  B00001,
  B11111
  lcd.begin(16, 2);
  lcd.createChar(0, newChar1);
  lcd.createChar(1, newChar2);
  lcd.createChar(2, newChar3);
  lcd.createChar(3, newChar4);
  lcd.createChar(4, newChar5);
  lcd.createChar(5, newChar6);
  lcd.print("Voltage: ");
  lcd.print(voltage);
  lcd.print("V");
  lcd.setCursor(0, 1);
  if (voltage > 4.1 ){
    lcd.print("100%     ");
    lcd.write(byte(2));
    lcd.write(byte(1));
    lcd.write(byte(1));
    lcd.write(byte(1));
    lcd.write(byte(0));
  if (voltage > 3.8 && voltage < 4.1 ){
    lcd.print("75%      ");
    lcd.write(byte(4));
    lcd.write(byte(1));
    lcd.write(byte(1));
    lcd.write(byte(1));
    lcd.write(byte(0));
  if (voltage > 3.5 && voltage < 3.8 ){
    lcd.print("50%      ");
    lcd.write(byte(4));
    lcd.write(byte(3));
    lcd.write(byte(1));
    lcd.write(byte(1));
    lcd.write(byte(0));
  if (voltage > 3.3 && voltage < 3.5 ){
    lcd.print("25%      ");
    lcd.write(byte(4));
    lcd.write(byte(3));
    lcd.write(byte(3));
    lcd.write(byte(1));
    lcd.write(byte(0));
  if (voltage > 3.0 && voltage < 3.3 ){
    lcd.print("0-25%    ");
    lcd.write(byte(4));
    lcd.write(byte(3));
    lcd.write(byte(3));
    lcd.write(byte(3));
    lcd.write(byte(0));
  if (voltage > 2.5 && voltage < 3.0 ){
    lcd.print("Warning! ");
    lcd.write(byte(4));
    lcd.write(byte(3));
    lcd.write(byte(3));
    lcd.write(byte(3));
    lcd.write(byte(5));
    lcd.clear();
