Little help on 'if' commands (LCD serial)
Right, before I start I got this code from the arduino page. I have tried to edit it so i can switch some inputs on and off etc.
So I find this proggraming language really difficult and if any one can recomend me a cook to learn C a lot better (for arduino) please let me know. I am currently reading 30 arduino projects for the evil genius and it doesnt really teach you the programming side :/.
here we go, My code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
void setup(){
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // initialize the serial communications:
  pinMode(9,OUTPUT);
 if (Serial.available()) {
    if (Serial.read() == "1");
     digitalWrite(9,HIGH);
lcd.clear();
    while (Serial.available() > 0) {
      lcd.write(Serial.read());
Like I said I got it from here: http://arduino.cc/en/Tutorial/LiquidCrystalSerial
and I just want it so that if i send the number 1 over serial it turns the back light on (for the LCD) and if any one can be a really nice person could they also include a if statement of the number 0 it turns it off? :slight_smile: It would be really awesome and thank you for taking a look. The problem at the moment is I get the error codes: LCD_example.cpp:
In function 'void loop()':
LCD_example.pde:-1: error: ISO C++ forbids comparison between pointer and integer
LCD_example.pde:-1: error: expected `}' at end of input
Thanks again :slight_smile:
The Serial.read function returns a byte, or character. That single character will NEVER equal a string.
I'm nearly certain that the example in the book did not have a semicolon on the end of the if statement, either.
if(Serial.read() == '1')
would work a lot better.
trevorboultwood:
Serial.read() is returning a character value, but "1" is the address of a character array with a 1 in it.
Change to single quotes should do the job here:
    if (Serial.read() == '1');
