little help please on sketch
struggling a little finishing the sketch off
led light that comes on at 10kmph and stays on, Now need to add a button input and say if button is pressed then enable 10kmph cut off if not pressed then ignore 10kmph cut off
The sketch so far
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); ;
#include <NMEAGPS.h>
#include <NeoSWSerial.h>
NeoSWSerial gpsSerial(6,7);  // gps on pins 6,7
NMEAGPS gps;
const int WARNING_LED_0 = 10;   // warning led on pin 10 over
  pinMode( WARNING_LED_0, OUTPUT );
  digitalWrite( WARNING_LED_0, LOW ); // (RELAY OFF IN NORMAL STATE)
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print( F("Speed warning") ); // F macro saves RAM!
  gpsSerial.begin(9600);
  delay(2000);
  lcd.clear();
void printTime( NeoGPS::time_t & time )
  if (time.hours < 10)
    lcd.print( '0' );
  lcd.print( time.hours );
  if (time.minutes < 10)
    lcd.print( '0' );
  lcd.print( time.minutes );
  if (time.seconds < 10)
    lcd.print( '0' );
  lcd.print( time.seconds );
} // printTime
void displayGPS( gps_fix & fix )
  int kmh = 0;
  // Print speed
  lcd.setCursor(0,0);
  if (fix.valid.speed && (fix.spd.whole > 5)) {
    kmh = (fix.spd.whole * 185) / 100;
  lcd.print( kmh );
  lcd.print( F(" km/h      ") );
if (kmh > 10) {
digitalWrite( WARNING_LED_0, HIGH ); }
  // Print time
  if (fix.valid.time) {
    printTime( fix.dateTime );
} // displayGPS
  while (gps.available( gpsSerial )) {  // if there is data coming from the GPS shield
    gps_fix fix = gps.read();           // get the complete fix structure
    displayGPS( fix );                  // Show pieces of the fix on the LCD
How do you want the switch to act? Do you want the switch to toggle between 10kmph cut off enabled and 10kmph cut off disabled. I mean, one push enables and the next push disables?
yeah which ever is easiest
Create a boolean variable called (say) kmphLedEnabled and start with it false. Then every time you press the button the value changes between false and true.
In your other code have something like
if (kmphLedEnabled == true) {
   if (kmh > 10) {
else {
As a separate comment, if you use the AutoFormat tool to indent your code consistently it will make it much easier to understand.
...R
thank you
NMEAGPS gps;
const int kmphLedEnabled = 8;
  pinMode ( kmphLedEnabled, INPUT );
  lcd.begin(16, 2);
  lcd.clear();
  delay(2000);
  lcd.clear();
    lcd.print( '0' );
    lcd.print( '0' );
    lcd.print( '0' );
} // printTime
  int kmh = 0;
  // Print speed
  lcd.setCursor(0,0);
  lcd.print( kmh );
//if (kmh > 10) {
//digitalWrite( WARNING_LED_0, HIGH ); }
   if (kmh > 10) {
else {
  // Print time
} // displayGPS
Any other help at all please
Help with what?
the code struggling implementing what robin mentioned bud
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\shed1\Documents\Arduino\sketch_aug07a\sketch_aug07a.ino: In function 'void displayGPS(gps_fix&)':
sketch_aug07a:85: error: a function-definition is not allowed here before '{' token
sketch_aug07a:92: error: expected '}' at end of input
exit status 1
Here is a sketch to demonstrate toggling the state of the 10kph enable (and the LED on pin 13) with a pushbutton using the state change detection method to sense a button press. Add the function to your code (outside of loop()) and call the checkButton() function each time through loop(). The button will be checked 20 times per second.
This code compiles and has been tested on my Uno, IDE ver 1.8.5.
// program to toggle the enable state using a momentary switch.
const int  buttonPin = 4;    // the pin that the pushbutton is attached to
const int ledPin = 13;
boolean buttonState = HIGH;         // current state of the button
boolean lastButtonState = HIGH;     // previous state of the button
boolean enableState = false;  // enable 10kph cutoff when true
   // enable internal pullup on button pin
   pinMode(buttonPin, INPUT_PULLUP);
   // initialize the LED as an output
   pinMode(ledPin, OUTPUT);
   checkButton();
void checkButton()
   static unsigned long timer = 0;
   unsigned long interval = 50; // check button 20 times per second
   if (millis() - timer >= interval)
      timer = millis();
      buttonState = digitalRead(buttonPin);
      // compare the buttonState to its previous state
      if (buttonState != lastButtonState)
         if (buttonState == LOW)
            // if the current state is LOW then the button
            // went from off to on:
            digitalWrite(ledPin, !digitalRead(ledPin));  //toggle led
            enableState = !enableState;  // ***************toggle enable state
      lastButtonState = buttonState;
thank you shall try again
ktnch:
If you continue to have problems post the latest version of your program AND tell us in detail what happens when you run the program and what you want it to do that is different.
...R
will do quite new at this so its a matter of putting code and brackets in the right places
These links may help you to incorporate my function into your code (combining or merging codes).
https://arduino-info.wikispaces.com/CombiningArduinoSketches
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
